Old 05-29-2013, 12:44 PM   #4
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: Pre-LS swap questions
I would say try to find a motor as complete as you can and then try and run everything that came with it (i.e. brackets, intake manifold, exhaust manifolds, etc). I dont have any experience with the 50's trucks but I would try the stock parts first to try and save money. You might be able to trim your problem areas a little and then box it back in for security.
I understand the "wanting" the car manifold for looks but the truck manifold can be cleaned up. Picture from this build thread. But the truck manifold definately will work better in a truck that sees some towing.
On you torque converter question, yes you can use the stock. In fact you would not want a higher stall for towing. It would slip more and generate more heat.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
