Old 06-09-2013, 06:51 PM   #1
High ho silverado
High ho silverado's Avatar
83 Chevy Shotbed Silverado 4x4 6.0 swap
Hi guys i had done this swap over the winter time and just wanted to share it with you guys, let me know what you think and if it wasnt for this board and its members it would of been a long road and special thanks to "project Fred".
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 06-09-2013, 06:57 PM   #2
High ho silverado
Re: 83 Chevy Shotbed Silverado 4x4 6.0 swap
a few body shop pics, after my tbi 350 and drivetrain swap, bought truck to build new mudtruck but was in waaaaayyyy better shape than i thought when i got it home!
Dan G
Old 06-09-2013, 07:13 PM   #3
High ho silverado
Decided the tbi motor wasnt good enuff so i wanted to do a ls swap and started looking for a 5.3 to swap in and ended up getting a whole 03 6.0 truck fall in my lap at the body shop after i got it home. So i started over!
Dan G
Old 06-09-2013, 07:19 PM   #4
High ho silverado
And so it began........ Again! pulled the 6.0 and got to work!
Dan G
Old 06-09-2013, 07:25 PM   #5
High ho silverado
Broke down the motor and checked everything really good and cleaned it up and painted the block and valve covers, Black of coarse!
Dan G
Old 06-09-2013, 07:44 PM   #6
High ho silverado
Dan G
Old 06-09-2013, 07:54 PM   #7
High ho silverado
lots of test fitting and waiting on parts. (if you think u have everything and ready guess again)
Dan G
Old 06-09-2013, 08:05 PM   #8
High ho silverado
Then came the hard part, doing my wiring harness! i wanted to use the factory harness from the truck and the factory fuse block and relays, so i frankenstiend the two together (which took many hours of thought and soldering) and made it all look like it was from the day it came out, well with the exception of the ls.
Dan G
Old 06-09-2013, 08:22 PM   #9
High ho silverado
once i got all that worked out i moved on to the trans and headers.
Dan G
Old 06-09-2013, 08:28 PM   #10
High ho silverado
once that was all figured out it was out with the old and in with the new! sorry the pics are out of order a little but u get the idea. oh and dont look at my messy garage, cleaning isnt my strong suit!
Dan G
Old 06-09-2013, 08:33 PM   #11
High ho silverado
Dan G
Old 06-09-2013, 08:37 PM   #12
High ho silverado
Dan G
Old 06-09-2013, 08:41 PM   #13
High ho silverado
Dan G
Old 06-09-2013, 08:45 PM   #14
High ho silverado
Dan G
Old 06-09-2013, 08:48 PM   #15
High ho silverado
Dan G
Old 06-09-2013, 08:55 PM   #16
High ho silverado
and now for my assistant that none of this could of happened with out!
Dan G
Old 06-09-2013, 08:57 PM   #17
High ho silverado
If anyone has any questions feel free to ask! thanks for viewing
Dan G
Old 06-10-2013, 01:12 PM   #18
jon75
jon75's Avatar
What headers did you use? It doesn't look like you had to mess with clearance at all, so I am curious which ones you selected. The closest I've seen are the 2010 -2013 F-body headers.
What transfer case did you use? How did you hook up your speedometer? Did you use the factory sending unit for TBI setup? What are you doing about the voltage, oil pressure, and temp gauges?
Thanks....Enjoy that power!!
1975 GMC Sierra Grande K25HD 350-4BBL 4sp LWB
2009 Infiniti G37S Sedan w/Stillen sway bar kit & K&N Typhoon dual snorkel intakes
ASE certified for brakes, electrical diagnostics and heating and A/C & EPA certified in R12 and R134a
jon75 is offline   Reply With Quote
Old 06-10-2013, 05:53 PM   #19
High ho silverado
I used the schoenfeld headers for a 88 up, under 300 shipped, they were close to the trans on right side but not to bad, I was working with them on a 4 wheel drive set but they decided these were good. As far as gauges go I used the stock 90-91 burban gauges and t-case. For temp gauge I used the stock sender for a ls1 trans am as they have a 3 wire set up and work with my stock temp gauge. Then used a factory sender for oil pressure in the back of block with an adapter. U can put it in the oil cooler block off plate too which I suggest because of firewall. Everything works perfectly. I'm not a fan of gauges hanging off the dash. Hope this helps and yes it has more power than it needs that's for sure!
Dan G
Old 06-10-2013, 05:58 PM   #20
High ho silverado
As for gas tank I used a stock 87 tank and sender and put the right pump in it for my fuel pressure. It really was simple. There is a pic of the sender and how I set up the lines, I used the safety fittings for a ls1 and pushlock hose to go down to the lines. I reused the fuel lines from the 03 donor up to engine bay.
Dan G
Old 06-10-2013, 05:59 PM   #21
Jonboy
Slots go on anything!
Dan, do you have the pin outs for the temp sender? I need to do the same thing.
Jonboy is offline   Reply With Quote
Old 06-10-2013, 06:37 PM   #22
High ho silverado
I took the two wire plug apart and used the plug for the ac pressure sensor which is the same as the temp sender plug, and put them in the same spots and used the third wire for the green temp wire on my factory side harness. If that makes sense, if not I can do a picture to show u in a day or so.
Dan G
Old 06-10-2013, 06:57 PM   #23
Jonboy
That would be great. I am no no particular hurry.
