Old 07-03-2013, 11:50 PM   #1
Codez67Chevy
Codez67Chevy's Avatar
coil compressor
Just curious, when I finally get to the point of dropping my truck. Do I need to get a coil compressor to remove and install the new coils?
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 07-03-2013, 11:57 PM   #2
hayhauler71
hayhauler71's Avatar
Re: coil compressor
Nope drop lower control arm down install spring and jack control arm up and install lower ball joint nut
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-04-2013, 12:11 AM   #3
Codez67Chevy
Re: coil compressor
What about the rears though?
Members I've met...
Mister-B
Old 07-04-2013, 12:14 AM   #4
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: coil compressor
Jack the rear frame and put them on jacksatnds and start unbolting the spring cups, if the coils have cups with nuts welded on them your most likely going to snap them off which is no biggie, just a speed bump.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 07-04-2013, 12:16 AM   #5
Codez67Chevy
Re: coil compressor
Ok thanks guys.
Members I've met...
Mister-B
Old 07-04-2013, 01:07 AM   #6
cheyenne shortstep
cheyenne shortstep's Avatar
Re: coil compressor
Don't just let the lower A-Arm drop when you break loose the balljoints as this can be dangerous. I put a floorjack about an inch below the arm so it can't drop too far and then lower it down slowly once the balljoint is free as it will still be under alot of pressure.
cheyenne shortstep is offline   Reply With Quote
