Old 07-28-2013, 09:47 AM   #1
ozbowhunter
want your opinions
so the 82 is all painted its going to be left primer grey but im thinking of putting on some scallops and did a rendering just want to get your input
ozbowhunter is offline   Reply With Quote
Old 07-28-2013, 10:10 AM   #2
79Betty
79Betty's Avatar
Re: want your opinions
Of you like em do it to it. Remind me of the 80's, and i wasn't even born then lol. Be careful leavin it primer. It'll trap moisture quicker
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-28-2013, 10:33 AM   #3
ozbowhunter
was going to seal it with wax think that will help?
Old 07-28-2013, 10:45 AM   #4
kalbert
No.
If you really want the suede look to be long term you have to use paint, not primer. Real paint seals against moisture and is UV resistant among other things. There are a few sources for flat and semigloss hot rod paints, and they are not expensive. Tr Eastwood for one.
kalbert is offline   Reply With Quote
Old 07-28-2013, 11:28 AM   #5
BONUSCAB
It's not a '53 chevy. Just sayin...
BONUSCAB is offline   Reply With Quote
Old 07-28-2013, 11:50 AM   #6
ozbowhunter
whats that got to do with it glad you can tell the difference
Old 07-28-2013, 12:10 PM   #7
Axle
Axle's Avatar
Bottom line: primer is porous. It'll start rusting under the primer and you'll have rust bleed through if you don't put some sort of paint over it. And don't leave it outside until you get it painted.
Alex.
Axle is offline   Reply With Quote
Old 07-28-2013, 12:23 PM   #8
SkinnyG
SkinnyG's Avatar
Try three scallops from behind the front wheel, below the belt line only.
The one going forward, especially curving down up front is kind of odd. It puts curves in that don't suit the truck's lines.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-28-2013, 12:34 PM   #9
Ziegelsteinfaust
I would continue the top scallop over the step side fender to draw out the body.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-28-2013, 12:43 PM   #10
mrolds88
If you like the scallops, then do it. As far as what was said about primer and moisture is correct. What I would do is after everything is done, spray a coat or two of flat clear over the whole thing. That will seal everything and keep the look you have.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-28-2013, 01:42 PM   #11
BONUSCAB
You asked for our opinions. My opinion is, this 1950's-esque paint scheme will look silly on your truck. That is what it's got to do with it.
Old 07-28-2013, 03:02 PM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
You need a sealer to go over the primer basicly. As for scallops a double line behind the wheel wells could work but the early apache style trucks have the lines that work real well with them. Idk square trucks are hard to do anything with other than two tone or the factory lines from the sports and such. IMHO
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-28-2013, 03:03 PM   #13
79Betty
79Betty's Avatar
I'd lose the top one abd bring a couple back on the side step fender. Tie the bed into it. Nice ruby red metallic make it pop... Red interior and you'd be rockin.
Old 07-28-2013, 04:00 PM   #14
ozbowhunter
quote=BONUSCAB;6193654]You asked for our opinions. My opinion is, this 1950's-esque paint scheme will look silly on your truck. That is what it's got to do with it. [/quote]
its actually a 70s style paint scheme but thanks
Old 07-28-2013, 04:08 PM   #15
ozbowhunter
next style ??????
Old 07-28-2013, 04:08 PM   #16
Mikec10
Mikec10's Avatar
It might have been made popular in the 70s but pretty sure its been around since the 40s lol.
The curve thing is a little odd, but other then that i don't think its that bad, if you like it go for it. You should definitely lower it next though lol.
the second rendering you did, it looks kinda random just like there...
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 07-28-2013, 04:42 PM   #17
INSIDIOUS '86
What about putting them on the nose and leading them to midway on the door?
Old 07-28-2013, 05:59 PM   #18
ozbowhunter
yeah I know just busting some balls lol
Old 07-28-2013, 06:11 PM   #19
ozbowhunter
im thinking more like this now
Old 07-28-2013, 09:51 PM   #20
88Jimmy4x4
88Jimmy4x4's Avatar
any reason why your leaving primer and not paint it with color?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-29-2013, 06:36 AM   #21
ozbowhunter
just kinda like it that way always have done primer on my builds
Old 07-29-2013, 08:25 AM   #22
INSIDIOUS '86
Bring the lower one up to the marker light
Old 09-09-2013, 04:59 PM   #23
ozbowhunter
well its done and pics will be up soon and I wanted to let you all know I went over the primer with satin clear was a much better finish and looks better to thanks for the input
Old 09-09-2013, 06:29 PM   #24
Skunksmash
Skunksmash's Avatar
You said you want opinions. Whatever floats your boat, but I wouldn't do it. Then again I like my styling classy and high gloss. Some people like other styles.
Skunksmash is offline   Reply With Quote
