Old 07-28-2013, 03:35 PM   #1
primetime
primetime's Avatar
6 lug to 5 lug swap
I have my 72 5lug axles I want to swap over to my 68 rear end. What is my step by step process? I remember that the diff needs to be opened up to remove something, but I just can't afford any surprises when doing this swap.
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 07-28-2013, 03:51 PM   #2
67swb72klb
67swb72klb's Avatar
Re: 6 lug to 5 lug swap
they wont work 5 lugs are longer
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-28-2013, 04:07 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You will need to buy aftermarket 5-lug axles for the narrower 67-69 rearend.
Check Moser Engineering.
Keith
Convert to disc brakes.
Old 07-28-2013, 05:19 PM   #4
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
You should sell me those '72 axles. They will fit my '70. Send me a PM if you're interested. I'm up in Fort Mill, S.C. and come to Columbia frequently.
TobyArnot is offline   Reply With Quote
Old 07-28-2013, 08:06 PM   #5
primetime
primetime's Avatar
Well... That sucks. How about me swapping the entire rear end drum to drum?
Old 07-28-2013, 08:08 PM   #6
lolife99
lolife99's Avatar
Sure.
The 71-72 rearend is 1.5" wider (total) than your '68 rearend.
Keith
Old 07-28-2013, 08:31 PM   #7
primetime
primetime's Avatar
So if I was to swap the rear end, it would look like a clown car with the tires sticking out too far?
Old 07-28-2013, 08:50 PM   #8
lolife99
lolife99's Avatar
Not sure what you mean by that. Ha.
It's only 3/4" per side wider.
Keith
Old 07-28-2013, 09:13 PM   #9
1967chevytruckguy
take your axles out and drive them to rossville GA to hudlow axle and they can redrill them for 180.00 dollars
1967chevytruckguy is offline   Reply With Quote
Old 07-28-2013, 09:16 PM   #10
lolife99
lolife99's Avatar
And your brake drums.
Otherwise you will have to use 71-72 brake drums.
This will require the center hub of your 6-lug axles to have to be machined to a smaller diameter.
Keith
Old 07-28-2013, 11:03 PM   #11
Chvy2NV
Your best bet is to go with the moser 5 lug conversion. I wouldn't mess with redrilling anything. Although it would work.
Chvy2NV is offline   Reply With Quote
Old 07-29-2013, 11:14 AM   #12
TobyArnot
TobyArnot's Avatar
I'm still looking.
Old 07-29-2013, 12:04 PM   #13
primetime
primetime's Avatar
I'm starting to notice the difference in some of the pics I see online of c10's. it isn't as bad as I had first visualized, but I can see the tires sticking out past the step sides in some applications. But doesn't that mean the step side fenders for swb are different sizes for 68-72 c10's ?
Old 07-29-2013, 12:06 PM   #14
primetime
primetime's Avatar
I'm still looking.
Let me thoroughly weight my options first before I make a decision. Because I really want to put some 5 lug cragars ss on this truck.
Old 07-29-2013, 05:33 PM   #15
SS Tim
SS Tim's Avatar
The C10-30 K10-20 stepside fenders are the same 68-72. 67 differs only by not having the marker cutout. IIRC there are eight different fenders covering 67-72 stepsides.
67 right
68-72 right
67 left
67 left w/115"wb w/side mount spare cutout
67 left w/side mount spare cutout, except 115"wb
68-72 left
68-72 left w/115"wb w/side mount spare cutout
68-72 left w/side mount spare cutout, except 115"wb
Any apparent placement of the wheel relative to the fender lip will depend on four things.
installed axle width WMS to WMS
wheel width
wheel backspacing
axle laterial centering
SS Tim is offline   Reply With Quote
