Old 08-01-2013, 11:26 PM   #1
ivorton74
ivorton74's Avatar
speedometer on ls swap
What are u guys running for a speedometer? I kinda wanted to keep my original 100 mph speedometer. i'm considering goin aftermarket...is there a cheap one I can go with? those Dakota digital gauges are so pricey man.
ivorton74 is offline   Reply With Quote
Old 08-01-2013, 11:43 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: speedometer on ls swap
Do we really need a speedo? I look at it like this...somebody runs into the back of me, I guess I was not driving fast enough! Sorry man , I had to toss that in (for fun) A little info on the combo/eng/trans, might help? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-02-2013, 12:02 AM   #3
ivorton74
ivorton74's Avatar
i'll be swappin a 99 Silverado 5.3/4l60 in my 74 chevy.
Old 08-02-2013, 03:26 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It'll take a cableX if you want to run a gear driven speedo on an ls swap. Otherwise any electric speedo you can find would work. You can even just use a gps if your in a pinch for a short time while finding a more elegant solution.
I chose to make the tach the centerpiece of my dash, so my speedo is a function of the Scangauge II that I have. It small and runs off the ECM, has like 50 functions, one of which is speedo. The display is not large, and is digital only, but its plenty readable from where I sit, and since it can display other stuff and scan the ecm, its a swiss army knife in the cab.
take a look at the "testing lights " video I posted in my build, it shows the scangauge at night, and I have some pictures of it on the dash in the build as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-02-2013, 05:13 AM   #5
DjS71
Added link, this is what I'll go with until I can afford a VHX setup. First things first though.... I still need to buy an LSx
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 08-02-2013, 09:35 AM   #6
Jonboy
Slots go on anything!
I am going with a 90-91 R cluster. It looks fairly original.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-02-2013, 10:06 AM   #7
Custom 68
Custom 68's Avatar
I just used an electric AutoMeter speedo. It was the easiest for me at the time
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-02-2013, 10:22 AM   #8
wgeyer88
If you want to keep the original look, check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=512751
There's quite a few of us going with this option.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 08-02-2013, 10:33 PM   #9
ghettoluxury
ghettoluxury's Avatar
For the square body trucks most guys are using a cluster out of a 90-91 Blazer or Suburban. It has electric speedo and is a direct bolt in, the thing I don't like about it is that it only goes to 85 mph. I am currently working on a 120 mph speedo with tach for mine, using gauges from a 2000 Hyundai Sonata.
ghettoluxury is offline   Reply With Quote
Old 08-03-2013, 01:32 AM   #10
ivorton74
ivorton74's Avatar
yeah that's why I didn't want to go with the burb cluster too..i wanted to keep my 100mph speedo....maybe ill just have to suck it up and get it until I can get an autometer speedo.
Old 08-03-2013, 03:58 PM   #11
mooseknuckles
mooseknuckles's Avatar
I have all elec. auto meter gauges, bought them all individually....used my gps as the speedo till I could afford the auto meter unit. set on 6cyl. check these guys out....http://www.classicdash.com/shopping/...87/Auto-Meter/
mooseknuckles is offline   Reply With Quote
Old 08-05-2013, 08:12 PM   #12
Jon01
Jon01's Avatar
www.garmin.com
Jon01 is offline   Reply With Quote
Old 08-06-2013, 12:38 AM   #13
ivorton74
ivorton74's Avatar
so I decided just to go with the cable x set up...its about $300 so not too bad...i'll just use my tom tom until I can afford it.
Old 08-06-2013, 08:52 AM   #14
Jon01
Jon01's Avatar
I've got a slightly used cable-x I would sell. $250 shipped and it's yours.
Old 08-06-2013, 06:42 PM   #15
ivorton74
ivorton74's Avatar
im interested but have no cash right now...i'll let u kno when I have the cash...hope u still have it by then lol
Old 08-10-2013, 03:41 PM   #16
solidaxel
solidaxel's Avatar
How slightly used is it ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-10-2013, 05:19 PM   #17
Jon01
Jon01's Avatar
If I didn't tell you it was used you wouldn't know it.
Old 08-11-2013, 01:11 AM   #18
solidaxel
solidaxel's Avatar
Did you use something different?
LS 3 4L70E
Old 08-11-2013, 08:29 AM   #19
Jon01
Jon01's Avatar
I'm going to do the electronic conversion that LS1Nova71 came up with this winter.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
