Old 08-02-2013, 10:03 PM   #1
sduckworth13
sduckworth13's Avatar
Anyone know the coilover part number that comes with the Porterbuilt stage 2 kit
I'm assuming that the coilover shocks that come in the Porterbuilt stage 2 setup for the rear end are just the sleeve type and I would like to cross reference the part number to a true coilover shock. Thanks for any help.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-03-2013, 09:01 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Anyone know the coilover part number that comes with the Porterbuilt stage 2 kit
I'm confused by your question.
As far as I know the Stage two rear kit comes with standard KYB shocks.
The Porterbuilt rear coilover kits do use REAL coilovers.
They are RideTech's newest coilovers. ($$$)
http://www.ridetech.com/store/coil-overs/
Keith
Convert to disc brakes.
Old 08-03-2013, 09:17 AM   #3
sduckworth13
Keith,Ok you've always have been there to help me out and your the reason I know anything about any suspension at all. I'm baffled what's confusing that I said.
Scott
Old 08-03-2013, 09:19 AM   #4
lolife99
lolife99's Avatar
I may understand your wording now.
Porterbuilt sells a coilover kit that uses a 4-link rear suspension.
He also has a coilover kit that uses his tubular trailing arms.
(I assume this is the Stage 2 Coilover kit)
Both still use RideTech's coilovers,... which like you said is a "monotube" design.http://www.ridetech.com/tech/coiltech/#cutaway
Keith
Old 08-03-2013, 09:24 AM   #5
lolife99
lolife99's Avatar
What brand coilover do you want to run?
I think Fox makes these for RideTech and I've heard good things about them.
They are available in 3 different versions:
"Available as a fixed valve, rebound single adjustable, or triple adjustable shock."
Keith
Old 08-03-2013, 09:25 AM   #6
sduckworth13
Ok thanks for the info, I was also wondering what the part number was to cross reference. Thank you Keith
Scott
Old 08-03-2013, 09:28 AM   #7
lolife99
lolife99's Avatar
I would just contact Porterbuilt directly.
Keith
Old 08-03-2013, 09:30 AM   #8
sduckworth13
I think I'd like to go with the triple adjustable coilover. I didn't realize there were different options available.
Scott
Old 08-03-2013, 09:39 AM   #9
sduckworth13
I will call them Monday. Thanks Keith, you always come thru for us here on the board.
Scott
Old 08-03-2013, 11:23 AM   #10
oldman3
oldman3's Avatar
Keith, I think he was referring to the cheap sleeve type coil over and not the one were the threads are part of the actual shock. This is what I call the sleeve type...Jim
oldman3 is offline   Reply With Quote
