60-66 Nut
1960 And 1961 Owners Please Help
As some of you may know, I volunteered to help member twouvakind determine the changes necessary to make his windshield wiper delay work with the '60-'66 trucks. I have sorted through the wiring and wiper switches for the '62-'66 years, but I need help in confirming the wiring on the '60 and '61 trucks. I have a cab with wiring, that I believe is a '61 (VIN tag is gone) and a corresponding wiper switch. This seems to be about the only change to the wiper wiring. I am having trouble finding a '60 and '61 locally to confirm my suspicion that the '60 and '61 both have the same wiper wiring. So I was hoping some of you guys with '60's and '61's could take a peek at your wiper switch wiring and let me know if yours looks the same or similar to the pics below.
[IMG] [/IMG]And here are a couple pics of the wiper switch. This one happens to be a 2 speed with the washer. [IMG] [/IMG]![]() ![]() I also learned something in doing all this research on the wiper motors and switches. I used to think that '63 was the first year for the 2 speed and washer option. That is not so, they were available in at least '61 and '62. I have not confirmed if it was available in '60. So if one of you has a '60 with the 2 speed wipers and washer, please post up.
Re: 1960 And 1961 Owners Please Help
Don't know if it helps any CaptanFab, but the kick panels w/cables should be 60-61, so I think your right on the year. Also....my 2 speed switch and wiper motor were supposedly pulled from a 62 and I have the same switch as posted above. Im just missing the wiring harness, so can't help there.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Oct 2006
I should be getting my truck back soon, and will snap a few pics for you then .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Would GMC matter? I can look tonight at mine. I know it is only single speed though.
Who Me?
Sorry, mine is only a one speed and no washer.
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
GMC's n H.D.'s too!
Finally made it home tonight.
Mine is single speed, and GMC. The wire is white (I think). |
#8 | |
60-66 Nut
Thanks for the confirmation VonDog. I was hoping that the '60 wiring was the same as the '61 wiring
Thanks for the reply chevy_man5. Yes the white wire is the correct one.
one speed on mine sorry
1961 crewcab
I have a 60 cab, and a 61 chev and gmc, all are going to be washer free,, but I will take a look and get some shots for you.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1961 crewcab
the only one that had anything left was the 61... just standard wiper though... 1 white wire that goes into the harness.....
btw check out the wasp nest on the cluster!!
60-66 Nut
Thanks for the pics Jon.....Yeah, looks like they built a condo in there.....hope you didn't get stung?
1961 crewcab
I didn't see the nest until just now.....the 60, also had the one white wire, but it had been cut and spliced with something,, it was a 60 series the 61 gmc4000, same deal 1 white wire...
60-66 Nut
Yep, the '60-'63's all seem to have just the white wire for the single speed wipers
#15 |
Captain,
I have a '61 Chevy standard package and I confirmed that it has the original 2 speed wiper motor. No washer. Did you get your pic you needed or is this enough?
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
#16 |
60-66 Nut
My main objective with this thread was to confirm that both the '60 and '61 with the 2 speed wipers and washers, have the same switch and wiring as in the pics that I posted in post #1. This is in a effort to help member twouvakind with his installation instructions for the wiper delay that he is making for the '60-'66 trucks. Thanks for your input.
| Bookmarks |
