Old 08-08-2013, 05:29 PM   #1
marlo
1987 stepside fender
Hi, My name is Marlon, and I'm in Canada. I have a 1987 Chev. stepside, and have done a full duel gas tank install. The only part I need is a square hole drivers side rear fender. As far as I can see there are no repop's. And aside from grafting a pass. side door onto the drivers ( would be upside down ) I was wondering had anyone tried something similar, or might know of any parts dealers. Thanks!
marlo is offline   Reply With Quote
Old 08-09-2013, 07:23 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: 1987 stepside fender
I have been thinking about this same installation and have convinced myself to use a short fill hose on the tank and fill through the wheel opening (no fuel door on the fender).
Would that be an acceptable alternative for you?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-09-2013, 08:33 AM   #3
Greenlee
Greenlee's Avatar
I went through the same thing. I finally found a used fender with the square gas door. Not sure why there are no repops available when they came from the factory with a fuel door.
Greenlee is offline   Reply With Quote
Old 08-09-2013, 08:47 AM   #4
1981Stepside
1981Stepside's Avatar
Same here
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 08-09-2013, 09:51 AM   #5
marlo
K
That's what I'm doing, and it'll look pretty good with some SS parts. But down the road, I hope to find a fender. It was a factory option, but I believe it to be a "rare" one for these years. I have had no trouble finding the older fender, but it's not for me. maybe I'll post some pics of what I've done, in case anyone is interested. The Pass. side fill neck has been drilled out, and chromed, and SS button heads were used to remount, and would like to do the same on the drivers side. I have NOS fill hoses, for the right, but will need to cut, a fab it to work on the drivers side, also a drivers fill neck, is just as hard to find. I've hit every scrap yard, all used part dealers, and everything in between.
Old 08-09-2013, 10:50 AM   #6
tex_waco_usmc
Project Heaven in my 67!!!
Couldnt you graph in a door from a fleetside truck? Just a question, not too familiar with the stepside bed fuel doors.
tex_waco_usmc is offline   Reply With Quote
Old 08-09-2013, 12:10 PM   #7
marlo
I'm not to sure, I'll have to go to the wreckers again and have a look, but I don't think so. The full neck housing might be way off.
Old 08-09-2013, 12:13 PM   #8
Keith Seymore
Shouldn't be "too" rare; perhaps the combination of the dual tanks (not rare) and the stepside box (not rare) are making this hard to find.
One observation: You must have an earlier box, because in 1987 the primary fuel tank was on the driver's side. Passenger side was the secondary tank.
Since you are looking for a later fender/box it seems that should help you in your search.
K
1979-1986
1986 - 2019
