![]() Join Date: Jan 2013
Speedometer off after new trans
After putting in a 2004r, it seems my speedometer is off. I havent checked anything, but its pretty obvious when Im blowing by every car on the road and the speedo says Im under the speed limit
I had BTO put the right speedo gears in the trans, and gave them my gear ratio/tire size. But it still seems off. What can I do to test and fix this? Kinda at a loss here
Josh 72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs... |
Re: Speedometer off after new trans
I had to change gear several times before getting it right. BTO was very good about exchanging gears with me until it was right.
Use a gps to check to see how far off you are and give BTO the info, they will get you straight.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives
Active Member
![]() Join Date: Jul 2007
That's what I did to check the speed on my 68 after exchanging driven gear to get the right speed. First I checked to make sure the GPS was accurate by testing it with my Trailblazer. It was right on the money at several speeds (I have two GPS's and both were exact).
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Oh I didnt even think about GPS.
Did you have to take the trans to bowtie and have them change the gears?
![]() Join Date: Feb 2011
MusicMan70 1961 GMC Suburban |
#6 | |
Gear change is easy, just one bolt to pull the housing the speedo cable goes into. Posted via Mobile Device
#7 | |
Active Member
When you do remove the bullet, notice the color and maybe count the teeth of the internal drive gear. That way you can have some way to match the gears and/or let the vendor know what you have.
| Bookmarks |
