Old 08-11-2013, 09:47 AM   #1
jcd9730
jcd9730's Avatar
Speedometer off after new trans
After putting in a 2004r, it seems my speedometer is off. I havent checked anything, but its pretty obvious when Im blowing by every car on the road and the speedo says Im under the speed limit
I had BTO put the right speedo gears in the trans, and gave them my gear ratio/tire size. But it still seems off.
What can I do to test and fix this? Kinda at a loss here
Josh
72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs...
jcd9730 is offline   Reply With Quote
Old 08-11-2013, 09:54 AM   #2
slow-1
slow-1's Avatar
Re: Speedometer off after new trans
I had to change gear several times before getting it right. BTO was very good about exchanging gears with me until it was right.
Use a gps to check to see how far off you are and give BTO the info, they will get you straight.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 08-11-2013, 10:17 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by slow-1 View Post
...Use a gps to check to see how far off you are and give BTO the info, they will get you straight.
That's what I did to check the speed on my 68 after exchanging driven gear to get the right speed. First I checked to make sure the GPS was accurate by testing it with my Trailblazer. It was right on the money at several speeds (I have two GPS's and both were exact).
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-11-2013, 11:41 AM   #4
jcd9730
jcd9730's Avatar
Oh I didnt even think about GPS.
Did you have to take the trans to bowtie and have them change the gears?
Josh
Old 08-11-2013, 12:19 PM   #5
MusicMan70
MusicMan70's Avatar
Art Carr sells a speedo correction unit...scroll down a bit.
http://www.cpttransmission.com/
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-11-2013, 01:05 PM   #6
slow-1
slow-1's Avatar
Just remember with GPS, it is giving you your average speed so as you accellerate and decellerate the GPS speed will lag behind a bit...so to be most accurate drive at a steady speed.
Gear change is easy, just one bolt to pull the housing the speedo cable goes into.
Old 08-11-2013, 03:49 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Yeah, I drove at 20, 30, and on up to 70 for a few seconds on each speed. The driven gear is easy, the drive gear may be a little more difficult if you have to change that one. Every transmission is different.
When you do remove the bullet, notice the color and maybe count the teeth of the internal drive gear. That way you can have some way to match the gears and/or let the vendor know what you have.
06 Trailblazer
