Old 08-12-2013, 10:27 PM   #1
swamp rat
swamp rat's Avatar
light switch
I tried a search but it isn't working for some reason..
I want to replace my light switch, i know there is a button on the top side that needs to be depressed to remove the shaft but its not releasing, is there a trick to this?? Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-12-2013, 10:39 PM   #2
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: light switch
Pull the light switch out like the lights will be on then depress the button down and then it should come out. Hope this helps. Make sure you undo the battery first or your battery will run down. Hope this helps.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 08-12-2013, 10:50 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Re: light switch
^2 and then they can sometimes stick. You may have to give it a shot of WD40 or PB Blaster and work it a little also.
TBONE1964 is offline   Reply With Quote
Old 08-12-2013, 11:23 PM   #4
72 Sierra
Re: light switch
pull the swich all the way out and push on the button.the button wont go all the way down.keep pressure on the button and push switch in and out slighty not much.dont push all the way to parking light position.keep doing this and it will come out.button will go down when it releases.hope this helps
72 Sierra is offline   Reply With Quote
Old 08-13-2013, 01:12 AM   #5
swamp rat
swamp rat's Avatar
Re: light switch
Thank you (and the others) very much, such a simple thing when ya know the correct way. I was trying to push the button then pull it out from the off position..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
