Old 09-12-2013, 11:45 AM   #1
rs74
rs74's Avatar
Re: K30 frame question
I went out and was looking at the frame thinking about going ahead and shortening it. It only lacks a few inches at the very rear of the frame so I think one could get by with that. However, there is not any provisions in the frame for shock mounts on the outside of the frame since C&C's mount on the inside of the frame. That and I don't know if a truck bed would set on the frame the way it needs to. It might just don't know. Anyway it was a thought. I have an email in on a frame but it is out in Massachusetts and I am in Illinois.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 09-12-2013, 04:24 PM   #2
BONUSCAB
Here's my 1990 V3500, single real wheel. Shocks mount inboard just like yours. you can see the left shock mount on the frame, forward of the axle with no shock on it. I would find someone parting a truck and get the rear tails of the frame and have them welded to your frame to make it the correct length to fit a bed. That is what I had to do to mine due to the ends of my frame being damaged by a bumper being welded on.
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 09-12-2013, 05:07 PM   #3
rs74
rs74's Avatar
Well shoot, I thought the shocks mounted on the outside of the frame for pickup frames. I was under the assumption that only the C&C trucks mounted on the inside. IF I cut the frame down I will have to cut out two feet right behind the cab in order for everything to line up.
Roy
1987 R10 shortie
