where to find u-bolts for the lower control arms?
86 swb 2wd
Posted via Mobile Device |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: where to find u-bolts for the lower control arms?
Classic Parts of America has them.
I got my last set from my GM dealer. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
do these need to be replaced? i soaked mine an brushed them clean today. an how tight should they be tightned down to.
the threads like to get galled on the outsides, they seam to open up
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
I've taken mine off a few times. Just threw them in a vice and tightened them down to get them to go back in. Torque specs can prob be found via search. I tightened mine down to about eeerrghh ftlbs
if the threads are fine then you should be good to go otherwise they are cheap and cheap reassurance at thatPosted via Mobile Device
I got mine at NAPA
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
i think it was like 80 or more, i didnt grab the torque wrench. just cranked them down
ya there good. they came out with no problems. an none the threads got missed up. just cleaned them up an painted them black. just waiting for it to cool down a bit, to go back out there an reinstall. an ill make sure to tighten it down to EEERRGHH ftlbs lol. thanx again
At the body shop.
1/2 impact gun.
With no engine. But grrrr tight works Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
#11 | |
Posted via Inflatable pizza and a fancy lawn mower
#12 | |
Classic parts should have the cross shafts as well and the studs. Just about everything for the front suspension which is nice.
Your local Napa should have them.
| Bookmarks |
