Old 10-15-2013, 01:11 PM   #1
bblank79
Breaks
I parked my truck after driving it and everything working fine. The next day I go to drive it and no breaks what so ever, pedal goes straight to the floor? I have a 1970 Chevy C10. Any thoughts or ideas?
Thanks, Brian
bblank79 is offline   Reply With Quote
Old 10-15-2013, 01:20 PM   #2
cdowns
cdowns's Avatar
Re: Breaks
bad master cylinder or a bad leak ruptured brake lines cause no brakes problem
Old 10-15-2013, 01:23 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Breaks
Is there a puddle on the ground? Start with the fluid level in the MS and trace the lines for a leak.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-15-2013, 02:15 PM   #4
MARKDTN
Re: Breaks
What they said.
I vote for bad master cylinder, but more checking is necessary.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-15-2013, 02:44 PM   #5
rsavage
rsavage's Avatar
Re: Breaks
You could have a BREAK in your BRAKE line
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-15-2013, 03:19 PM   #6
zeldman
zeldman's Avatar
Re: Breaks
Thank you rsavage....
Check the master cylinder, make sure it is full. If not look for signs of leakage from behind the master cylinder. It is possible a brake line rusted and ruptured, or possibly a brake cylinder came apart. Thank God it happened while parked and not while you were driving it.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
