Old 10-21-2013, 09:56 PM   #1
62lwbc10
Big back window conversion?
Hey all I recall one member taking this on but not sure what the result was. Has anyone performed this conversion? How did it come out? I imagine this would be a huge undertaking. Curious if it's really possible.
62lwbc10 is offline   Reply With Quote
Old 10-22-2013, 10:00 AM   #2
mr48chev
mr48chev's Avatar
Re: Big back window conversion?
I think there is one in the projects/build threads section but may be mistaken.
Unless the rest of my cab was nearly perfect I think I would just consider getting a decent big window cab and prep it, paint the interior, put what ever coating on the bottom and swap cabs.
My ongoing truck projects:
Old 10-22-2013, 11:12 AM   #3
rgunlock
rgunlock's Avatar
I think you are referring to thump16's thread.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 10-23-2013, 01:38 PM   #4
Rude Dude
Rude Dude's Avatar
Look at this thread, done right.
http://67-72chevytrucks.com/vboard/s...528853&page=10
Rude Dude is offline   Reply With Quote
Old 10-23-2013, 02:13 PM   #5
mr48chev
mr48chev's Avatar
Yes sir I was, come to think of it and I can't think of a better tutorial to send someone who is considering doing it to.
It also will very quickly let a guy or gal figure out if they are up to the task and want to undertake it.
Old 10-24-2013, 04:31 PM   #6
_Ogre
_Ogre's Avatar
looked thru thump's bbw conversion again.
$1200 in parts and a lot of work
but the finished product should look good, when he finishes it.
plus you get all new cab corners in and out
shop air compressor timer
Old 10-25-2013, 09:31 PM   #7
62lwbc10
I think, when the time comes, I will take on this challenge.
Old 10-26-2013, 07:46 AM   #8
Russell Ashley
Russell Ashley's Avatar
I'm considering it too, but getting rid of the straight axle is next on my priority list.
Russell Ashley is offline   Reply With Quote
Old 10-27-2013, 12:17 AM   #9
Zach B
Zach B's Avatar
My uncle is doing the conversion right now on a 66. The catch is that gm produced 3 cabs at the time. One was only for the small window (the truck he has). One was produce only for the big window. And a third had the small window but was designed so that you could cut the cab out for a big window. He found the third cab. It requires a lot of prep work but win carful cutting its by far the best way to go.
Zach B is offline   Reply With Quote
Old 10-27-2013, 09:41 AM   #10
thump16
thump16's Avatar
I had to stop work on my conversion due to my fathers brain cancer surgery. He is alive and well on the way to a healthy recovery considering his tumor was the size of three golf balls.
As far as the conversion itself, I have everything prepped and ready to weld in. Instead of using my small inner window frame I opted to use the one piece inner window and pillar.http://67-72chevytrucks.com/vboard/a...1&d=1352858580
So if anyone needs the inner window frame support Pic below, I have one in the attic.http://67-72chevytrucks.com/vboard/a...1&d=1352857140
thump16 is offline   Reply With Quote
Old 10-27-2013, 10:32 PM   #11
62lwbc10
Thump first and foremost Godspeed to your dad and all the best with his recovery . Do keep us informed about the progress you make with the conversion.
