Old 11-21-2013, 04:13 PM   #26
NurseBen
NurseBen's Avatar
Re: New member, K20
Size:  45.0 KB Spot light photo
NurseBen is offline   Reply With Quote
Old 11-21-2013, 04:13 PM   #27
NurseBen
NurseBen's Avatar
Re: New member, K20
Old 11-21-2013, 04:14 PM   #28
NurseBen
NurseBen's Avatar
Re: New member, K20
Old 11-21-2013, 04:18 PM   #29
NurseBen
NurseBen's Avatar
Re: New member, K20
My daughter and all the neighbor kids love to ride in "Big Blue" they could care less about my neighbors 2014 Ford F350 Platinum Edition $60,000 truck!
Old 11-21-2013, 04:18 PM   #30
NurseBen
NurseBen's Avatar
Re: New member, K20
Old 11-21-2013, 04:19 PM   #31
NurseBen
NurseBen's Avatar
Re: New member, K20
Old 11-21-2013, 04:32 PM   #32
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: New member, K20
The Bus Type Heater does the same as a stock Block Heater. You plug the 110V plug into a electrical socket and it will heat the engine and heater coil. Anything that comes into contact with antifreeze will be heated. Great for cold winter months start up.
My advise is to tear any wiring that doesn't come from the factory out of the truck and if necessary start over. Used Scrap Northern trucks have better wiring harnesses than southern trucks as there not dried out from the heat.
The switch on the dash is the one mounted under the dash to the right of the steering column?
Get yourself a 63 Shop Manual. The American Version has less illustrations than the Canadian version apparently. I have a spare if you need one.
Old 11-21-2013, 04:39 PM   #33
aerotruk63
aerotruk63's Avatar
Re: New member, K20
Unity Spotlight Bracket#31.
They came with a tapered rubber wedge for 60-63 Chevy trucks. They were used on other vehicles as well. Take a look for these when you spot an old Fire Truck.
Please tell me the hubcaps hanging on the wall, in post#28, are not from this truck?
Original spiral rear shocks!
Old 11-21-2013, 04:46 PM   #34
NurseBen
NurseBen's Avatar
Re: New member, K20
Here's the switch, also I forgot to mention I did replace the voltage regulator. I like to start with the most expensive and hardest part to replace then work backwards only to find its a loose wire, the wife loves that stuff!
Old 11-21-2013, 04:48 PM   #35
MisterC
MisterC's Avatar
Re: New member, K20
Just saw this thread. I'm along for the ride. Great looking truck you have there!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 11-21-2013, 04:49 PM   #36
b.sharp
b.sharp's Avatar
Re: New member, K20
it appears that in picture #16 that it still had the original factory steel wheels. Those are probably the factory hubcaps and I have been looking for a set of factory 8 lug wheels and caps for my 64 single wheel 1 ton 4x4 military truck. Who would think he would take them off....
b.sharp is offline   Reply With Quote
Old 11-21-2013, 05:00 PM   #37
aerotruk63
aerotruk63's Avatar
Re: New member, K20
63 4WD. did not come from the factory with hubcaps. All my literature states they did not, nor do you see any factory photo's with them on.
Old 11-21-2013, 05:02 PM   #38
aerotruk63
aerotruk63's Avatar
Re: New member, K20
Originally Posted by NurseBen View Post
Attachment 1178078
That's a statement that applies to many! lmao
Old 11-21-2013, 05:06 PM   #39
NurseBen
NurseBen's Avatar
Re: New member, K20
I welded some clips on the 16 inch rims and run the caps when I'm feeling a bit crazy.
Old 11-21-2013, 05:07 PM   #40
NurseBen
NurseBen's Avatar
Re: New member, K20
Without....
Old 11-21-2013, 05:07 PM   #41
RANDY COX
RANDY COX's Avatar
Re: New member, K20
Nice truck I have to ask what size tires are those and what brand. Thanks again Awesome.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-21-2013, 05:08 PM   #42
NurseBen
NurseBen's Avatar
Re: New member, K20
With.
Old 11-21-2013, 05:09 PM   #43
aerotruk63
aerotruk63's Avatar
Re: New member, K20
Whew, that would have started another headache!
Old 11-21-2013, 05:09 PM   #44
NurseBen
NurseBen's Avatar
Re: New member, K20
1 GMC and 1 Chevy, depending one which side of the truck your looking at.
Old 11-21-2013, 05:10 PM   #45
NurseBen
NurseBen's Avatar
Re: New member, K20
The spare
Old 11-21-2013, 05:11 PM   #46
NurseBen
NurseBen's Avatar
Re: New member, K20
The other four.
Old 11-21-2013, 05:24 PM   #47
NurseBen
NurseBen's Avatar
Re: New member, K20
The tires are Interco Super Swamper 34 x 16 x 10.5.
The spare and all the " original rims" have clips on them?
Old 11-21-2013, 05:29 PM   #48
aerotruk63
aerotruk63's Avatar
Re: New member, K20
oem4me has a set of 61-63 8 7/8 I.D. painted caps I think.
The ones from the front 58-60 Chevrolet
Both rears 66
Old 11-21-2013, 07:37 PM   #49
NurseBen
NurseBen's Avatar
Re: New member, K20
Thanks for the help and info on my truck.
Old 11-25-2013, 11:27 AM   #50
NurseBen
NurseBen's Avatar
Re: New member, K20
I posted awhile back that my battery would die if I turned the headlights on after driving for about 30-40 min. I went back and pulled all the plow wiring out from the headlights and re grounded the lights, took the family for a drive, turned on the headlights and bam the volt gauge drops! Turned on the heater and bam, the gauge drops all the way! Made it home with lights almost completely gone, backed into the garage, turned it off and of course no juice to start. I have replaced the alt and voltage regulator, but I am wondering if the alt is no good? Could my belt have anything to do with this? I fabed my own power steering bracket and am running a double pulley on the alt to the steering pump if this means anything. Thanks for the help.
