Old 11-21-2013, 06:38 PM   #26
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Blew it
If you can get a good 305 for a good price make sure its the LB9 from an iroc or the LE9 from a truck. Factory high compression pistons and the cams are better than any other. Headers intake and a recurve on the distributor wakes them up good. Factory 350vs 305 wasn't much diff. Just better mpg and 10less hp. The 305 was designed by gm to do the work of a 350 but use less gas.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-22-2013, 12:09 AM   #27
NASTY-LSX
Re: Blew it
Ill sell you the complete motor out of mine cheap. I already have a 454 replacement complete means drop it in and turn it on and go.. You can hear run and drive it if you like.
PM me your #
http://rs570.pbsrc.com/albums/ss150/...y1.jpg~320x480
NASTY-LSX is offline   Reply With Quote
Old 11-22-2013, 03:12 PM   #28
RastaRobb
RastaRobb's Avatar
Wink Re: Blew it
Buying crate is always a bite at first, but it eleviates the gamble. You know what you are getting, you know it's good, you know you will be happy with it. That being said, I'm off to the junk yard to see if I can find some parts.
RastaRobb is offline   Reply With Quote
