Old 12-02-2013, 12:58 AM   #1
Township21
Question Tips for filler neck gasket replacement?
Hey all ,
I have a stock '72 Chevy C10. I am trying to replace the exterior gasket on the fuel filler neck -- without taking out the filler neck itself. I looked in the service manual for instructions, for 'how to' videos on YouTube, and threads here in the forum, and haven't found anything that helps.
Any one know the best way to do this, or can point me to a website or video that shows how to do it?
Let me know -- thanks!
Township21
Township21 is offline   Reply With Quote
Old 12-02-2013, 08:02 AM   #2
quick60
quick60's Avatar
Re: Tips for filler neck gasket replacement?
I need to do the same thing just have not gotten around to it yet. Thanks for asking I will be checking back.
quick60 is offline   Reply With Quote
Old 12-02-2013, 09:19 AM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Tips for filler neck gasket replacement?
I don't know about it being the best are not but I can tell U how I did it and it was pretty easy.
Take the gas tank bolts loose so U have some play up at the neck and coat the neck with dish washing liquid to help it go in place. Warm the gasket up also in some warm water before U start.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-02-2013, 09:42 AM   #4
ksshane
ksshane's Avatar
I cant find the thread right now, but I remember reading how alot of people use dish soap on the gasket it to help slide it in place.
I ordered one from Wes (read alot of bad reviews about the more common gaskets cracking after 6 months or so), but waiting to do my body work and paint before installing it.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 12-02-2013, 10:13 AM   #5
Lee H
Lee H's Avatar
I used the dish soap and warm water trick without loosening the tank. Just pushed it in place.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-02-2013, 11:28 AM   #6
Township21
Thanks all -- I'll give this a try!
One quick q for KSShane -- I'm intrigued by your comment about 'common gaskets'. I just ordered one on line -- who is this "Wes" that you referred to?
Old 12-02-2013, 12:35 PM   #7
Mister-B
Soap on the gasket wasn't enough for me. It was way too tight on one side. I took a thick shovel handle, put it about 8" down the open fuel neck, then leaned on the handle gently to create a gap while I got it in place.
Have a wide flat head screw driver handy to push the edges down in to place
Mister-B is offline   Reply With Quote
filler neck, gasket, replacement
