cross member question!
hey guys ! couple questions here , i have an 86 and an 85. the 86 has mounting brackets for the rear body mounts of the cab and the 85 has a cross-member. the 85 originally had a hanger bearing but id like to put a straight drive-shaft in it. is it possible to order the brackets like on my 86 so the drive-shaft has room ? and how do you get the cross-member out without cutting it ?? i have the truck right down to the frame at the moment. will taking the cross-member out cause any issues ?
1986 LWB c10 w/327 & vortec heads
Re: cross member question!
Post some pics of solid crossmember. It really depends on how its mounted to the frame.
John 82 Chevy Silverado 350ci/TH350
It is rivited in ... But the 86 i have doesnt even have this crossmember so i cant see it being an issue..
I dont mind chopping up the original cross memeber in order to get itbout as long as i knowbthat i can get new brackets
#5 | |
Powertrain options can also drive a one piece shaft vs a two piece. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
| Bookmarks |
