Old 11-25-2009, 05:32 PM   #51
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: '72 Cheyenne Project - Kansas City
Very nice! Keep up the good work, don't give up on it.
Ryan
1969 Chevy milk truck
Old 12-01-2009, 02:28 AM   #52
420am
420am's Avatar
Thanks, I need all the encouragement I can get. I can see the light at the end of the tunnel.. at least for getting the top end bolted back together and running.
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 12-04-2009, 03:06 AM   #53
420am
420am's Avatar
Here's the new intake all clearcoated with some Eastwood Diamond Satin Clear. I love that stuff for bare metal. I topped it off with some ARP carb studs and a 1" spacer.
Info on the EPS intake..
Dual-plane Edelbrock Performer EPS intake manifolds deliver dyno-proven horsepower gains from idle to 5,500 rpm, when used with Edelbrock's Performer series square-bore or Thunder series AVS carburetors. Dyno tests showed an extra 5 HP and 9 ft.-lbs. over their own Performer manifold. The secret's in the all-new runner design, which is tuned to produce substantial torque increases in the 3,000-4,500 rpm range--with peak torque at 3,500 rpm. That's power where you need it the most!
Old 12-04-2009, 06:40 AM   #54
darkhorse970
darkhorse970's Avatar
I've been wanting to do the same thing to my intake, have you done this before on engine parts? Does the Eastwood clear hold up to the heat?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 12-04-2009, 10:54 AM   #55
420am
420am's Avatar
I haven't used any of the parts I've sprayed with it yet. It's supposed to be good for 350ºF. Here's the link to it: http://www.eastwood.com/specialty-co...sol-11-oz.html
I coated my old polished intake with it before I sold it and I coated my valve covers with the high gloss version. I like the way everything has turned out. It's nice to not leave fingerprints on my polished aluminum valve covers.
Old 12-04-2009, 10:57 AM   #56
420am
420am's Avatar
oh.. and just a note.. the hood in that pic is scrap. Just so the rust on it doesn't confuse people. I'll likely end up using it for patch panels.. right now it's serving as a workbench.
Old 12-07-2009, 09:50 AM   #57
420am
420am's Avatar
Just got some stuff removed and painted.
Old 12-07-2009, 09:55 AM   #58
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good, nice progress!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-20-2009, 02:17 AM   #59
420am
420am's Avatar
Gasket on and Copper Sealed.. about to make the mistake of bolting the heads on before we checked for TDC. haha.
While I'm tightening down some of the head bolts Brian notices something peculiar about the cam we pulled out.
Which reminds me that one of the pushrods was a little worse for wear. I thought maybe I'd roughed it up taking it out.. I sometimes employ Gorilla strength and it's well within the realm of possibility that I could have bent it.. that lobe tells otherwise though.
Ahhhh.. heads are on. Time for some pizza!
Decided to set most everything on the motor before we called it a day to see how it'll all look. I dig it, even though the timing gear is on backwards. Thanks for the help B!
Old 12-26-2009, 01:44 PM   #60
Ben IV
Engine looks great, what brand are those valve covers? I think im gonna have to get me a pair.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 12-26-2009, 02:11 PM   #61
420am
420am's Avatar
I bought them off of ebay. Those are the tall ones. Here's a link to the valve cover section of the seller's store that I bought them from:
http://stores.ebay.com/abad71camaro_...34Q2ec0Q2em322
In case that link doesn't work here's the link to the store, seller's handle is abad71camaro :
He had a lot of cool valve covers.. it was hard to choose between these and the ball milled ones.
Old 12-26-2009, 05:27 PM   #62
Sinister
Between Trucks...
Sinister's Avatar
Build's looking good. I just got some valve covers from that guy on E-bay. He has some nice stuff.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-25-2010, 02:36 AM   #63
420am
420am's Avatar
Old 12-10-2013, 09:14 PM   #64
420am
420am's Avatar
Sold.
Old 12-10-2013, 10:39 PM   #65
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Bummer. I had thought about you a week or two back.
-Nate
