Old 12-23-2013, 10:59 AM   #76
jae
Re: Project NiteMare-1970 C10 LWB build
That looks good!
jae is offline   Reply With Quote
Old 12-23-2013, 11:50 AM   #77
Molberg
Molberg's Avatar
Thanks Jae! (Had to clean shop... again)
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 01-04-2014, 09:15 PM   #78
Molberg
Molberg's Avatar
Quick update on something I've been workin on past few weeks. (still in progress) I wanted the centre bar of my '70 to continue to outside edges of frame, with lights inside if possible. I've never seen this done... maybe for good reason. I got my hands on a set of headlight assemblies from a 1992 grandprix gtp, and fabricated the bucket assemblies to hold it all. I ended up using 2 grille assemblies to do this. Just finishing the aluminum work off.. plastic inserts are fiberglassed and awaiting final repair. Aluminum pieces all stripped of anodizing and awaiting some tig work when completed..
-Project Nitemare-
Old 01-04-2014, 10:01 PM   #79
Gor77
Gor77's Avatar
looks great!
will be interesting to see in the dark with the lights
___________________________________
Dima
1970 Chevrolet C10 stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=569197
Gor77 is offline   Reply With Quote
Old 01-04-2014, 10:44 PM   #80
Molberg
Molberg's Avatar
Originally Posted by Gor77 View Post
looks great!
Thanks... goin to do a relay upgrade before I power them up
-Project Nitemare-
Old 01-06-2014, 12:16 AM   #81
cherokeejohn
cherokeejohn's Avatar
Your talent and skillfulness shows beautifully in your work. I love the detail on the skull molded into the console, and the grill is a unique "1-OFF" piece that i love" and again , shows your talents and visions. I find your work Inspiring. Keep up the awesome work , I'm signed up
72 C/10, LWB, 5.7, Auto, with A/C
F.B.I = Full Blood Indian
Appalachia/Eastern Cherokee,"Tsalagi"
cherokeejohn is offline   Reply With Quote
Old 01-06-2014, 09:21 AM   #82
Molberg
Molberg's Avatar
Wow... thank you cherokeeJohn. Very flattering.
These are somewhat build related.. had to stopworking on my truck to build them. (wife's Christmas present) Thought I'd share in case anybody else wants to get out of buying flowers... forever. Made from leftover 20 guage steel cut into 4x4 square pieces. Cut the 4 petal pieces, buzzed with a flap wheel on my grinder and bent to shape. Leaves made from same 20 guage, stems made from left over 1/4" brake line. All left bare steel and sprayed with clear coat when finished. The bolt that holds all the pedal pieces together, threads into the brake line. All from leftover project materials. She was grumpy with me xmas eve.. though I was working on my truck... again.
-Project Nitemare-
Old 01-06-2014, 09:29 AM   #83
Molberg
Molberg's Avatar
Finished off with some polished brass pipe cut to resemble rings.. and I annealed some 2" copper pipe and hammered it out for final touches. Back to the truck now.
-Project Nitemare-
Old 01-12-2014, 11:19 PM   #84
71' Custom
71' Custom's Avatar
This is an awesome build, subscribed!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Project: Under Pressure II
http://www.67-72chevytrucks.com/vboa...d.php?t=559720
71' Custom is offline   Reply With Quote
Old 01-12-2014, 11:47 PM   #85
zicc1835
zicc1835's Avatar
WOW, where does this talent end, you are truly gifted, please keep the pics and updates coming thanks for sharing
jz
zicc1835 is offline   Reply With Quote
Old 01-13-2014, 01:42 AM   #86
Willys47
Willys47's Avatar
i want to see how this one turns out
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 01-13-2014, 10:22 AM   #87
Molberg
Molberg's Avatar
Thanks for all the comments guys
-Project Nitemare-
Old 01-28-2014, 10:36 PM   #88
Molberg
Molberg's Avatar
Just updating my build thread while I'm having a beer and staring at it. All aluminum pieces were polished after stripping anodizing. The outer grille piece was going to be sprayed initially.. changed me mind.. had to polish it back after sanding it. (ouch) Masked it off and sprayed black lines and lettering. Light buckets were sprayed, installed and wired up. Made some bumper bolts with a poor mans lathe. (drill clamped in vise and metal shaped with an angle grinder) Polished when completed
-Project Nitemare-
Old 01-28-2014, 10:40 PM   #89
Molberg
Molberg's Avatar
The frame tips I removed were reworked to receive the modified bumper/rollpan. Fishplates welded to them.. and mating holes drilled through the plated and frame. Secured with bolts.. slotted for adjustment.
-Project Nitemare-
Old 01-28-2014, 10:55 PM   #90
Molberg
Molberg's Avatar
Going to back up a bit.. The rad cradle and forward edges of fenders had to be reworked to make room for the grille and headlight assemblies
-Project Nitemare-
Old 01-28-2014, 11:02 PM   #91
Molberg
Molberg's Avatar
The inserts were made with stainless rod.. and the frames were fabbed with 1" angle. Angle iron cut and shaped to match contour of the opening where it sits. I wanted the rod to continue from end to end with no visible reinforcement. 1/4" x 1" flat steel was used here. Holes marked and drilled for proper spacing of the rods... and then split in half with a zip cut grinder. They act as cradles, welding done on backside where it's not visible.
-Project Nitemare-
Old 01-28-2014, 11:06 PM   #92
Molberg
Molberg's Avatar
The grille was made in 4 pieces, placed into opening and tacked while on the truck for proper fit. Removed and welded. Backing plates welded in for strength... and a spot to fasten future mounting brackets to.
-Project Nitemare-
Old 01-28-2014, 11:07 PM   #93
Molberg
Molberg's Avatar
This is how it sits.. not sure if I'll spray them black or polish yet. I spent about a week fabbing up plastic inserts from 2 factory grilles. Fiberglass work all done (except final work) Installed it and hated it.. lol. So this is where I wound up.
-Project Nitemare-
Old 01-28-2014, 11:18 PM   #94
Bomp
Bomp's Avatar
Definitely an interesting look.
You sure have some mad skillz
sub'd
Bomp is offline   Reply With Quote
Old 01-28-2014, 11:28 PM   #95
Molberg
Molberg's Avatar
Thanks Bomp
-Project Nitemare-
Old 01-29-2014, 12:10 PM   #96
Evaded
Evaded's Avatar
Like where your going, real one of a kind stuff.
Evaded
If I see a Zombie.. Im runnin it over with my Truck.
Evaded is offline   Reply With Quote
Old 01-29-2014, 07:57 PM   #97
Molberg
Molberg's Avatar
Evaded
Thanks!
-Project Nitemare-
Old 01-29-2014, 10:37 PM   #98
71' Custom
71' Custom's Avatar
Man, that grill is sick!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 01-29-2014, 10:58 PM   #99
ejn74
ejn74's Avatar
Your metal skills rock
Life is short, Live each day as a new day and keep on Truckin!
ejn74 is offline   Reply With Quote
Old 01-30-2014, 07:06 AM   #100
CURSED GEARS
Good stuff. I'm assuming you built other stuff prior to this?
CURSED GEARS is offline   Reply With Quote
