Old 12-25-2013, 03:28 PM   #1
WIDE LOAD C-30
Anybody running an Ididit column in an AD truck?
I have an Ididit column from LMC in my '55 1st series and it works well but I have some parts that came with the column that I never used and never found out what they are for.
What are these for?
'55 3100 1st Series
WIDE LOAD C-30 is offline   Reply With Quote
Old 12-25-2013, 04:51 PM   #2
1952
1952's Avatar
Red face Re: Anybody running an Ididit column in an AD truck?
Well the clamp and the black thingy (lol) are to hold your lower column to the floorboard where the column goes through the floor and I suspect that the shiny thingy mounts on your dash original clamp holes to attach a drop for the column
1952 is offline   Reply With Quote
Old 12-25-2013, 05:05 PM   #3
WIDE LOAD C-30
But the clamp is not big enough to go around the column and the holes on "the shiny thing" do not match the column drop. I've even googled the part number and nothing comes up.
'55 3100 1st Series
Old 12-25-2013, 07:32 PM   #4
S10Fan
Old Heap Driver
I used a similar clamp and similar bracket (black one) to mount my stock style column to the floor.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 12-25-2013, 07:50 PM   #5
WIDE LOAD C-30
Got any pics?
'55 3100 1st Series
Old 12-25-2013, 11:50 PM   #6
1952
1952's Avatar
the shiny one is part #2301050010 and is a dash bracket for chev trucks
The other are parts for floor mount on 55-57 chevs that mount through original floor holes
Hope that helped
Old 12-25-2013, 11:56 PM   #7
1952
1952's Avatar
http://www.ididitinc.com/accessories...mnDrops_Acc-21
you can find it here
Old 12-26-2013, 08:22 PM   #8
S10Fan
Old Heap Driver
Originally Posted by WIDE LOAD C-30 View Post
Got any pics?
Here ya go. I used a piece of my stock column that was cut off when connecting to the S-10 steering box, cut the tube in half, made a bracket similar to the one you posted, welded everything together, clamped the column and bolted the bracket to the floor. Works great.
Bryan
Old 12-26-2013, 10:02 PM   #9
WIDE LOAD C-30
This is the bottom of the column, obviously.
And this is how the column is mounted at the dash. The dash feels flimsy/weak If I pull on the steering wheel or when I put it in gear. I almost feel like the truck is missing something under the dash because I don't know what to do with the "shiny" part.
'55 3100 1st Series
