Old 01-25-2013, 05:21 PM   #1
54blackhornet
54blackhornet's Avatar
Hazard Switch Stuck on ?
Remember when you where told to "Look But Don't Touch" ! Well I pushed the hazard switch in on my 71 GMC, Good news is it everything works, all lights are blinking ! But when I go to pull the switch back out, It won't budge, Not a bit, WTF is going on ? Pulled the relay to get lights to stop blinking, Anyone had this happen ? I figure it must be the first time the switch was used since Nixon was in the White House...........Thanks Guy's Have a nice Weekend !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-25-2013, 05:29 PM   #2
70chevytruck
Re: Hazard Switch Stuck on ?
yep...me too...the truck had sat for 15 years...everything worked great. Had to use plyers to get it unstuck and broke the switch. Yea! Now i get to tear into the column.
Try some wd40 sprayed in there first...will also help your shifter if it is jancky. I could hardly shift out of park.
70chevytruck
70chevytruck is offline   Reply With Quote
Old 01-25-2013, 05:57 PM   #3
54blackhornet
Glad you mentioned that ! My column auto shifter is real hard to move too ? What is proper way to lube the shift linkage ?...thanks have a good one ! Rain today, snow last week
71 C-20
07 Magnum RT AWD
Old 01-25-2013, 11:26 PM   #4
ole dollor
ole dollor's Avatar
mine has a new turn signal switch, and its hard to pull out also....just pull harder and lube it up some...and try not to use it much....good luck.
ole dollor is offline   Reply With Quote
Old 01-09-2014, 11:25 AM   #5
underliner6
underliner6's Avatar
Is there any update on unsticking the hazard light button? Pressed mine today, and the hazards are stuck on. I unscrewed the mounting screw and removed the whole button but that did not fix the problem.
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
1971 K5 Blazer
underliner6 is offline   Reply With Quote
Old 01-09-2014, 12:51 PM   #6
treeboy97
treeboy97's Avatar
I also have a question concerning the hazard switch, who sells a good replacement. I have two columns and both hazard buttons are broke. I plan on painting the no-shift column this winter and hope to replace the button.
thanks
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E
2012 Victory Cross Country Touring
I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time.
treeboy97 is offline   Reply With Quote
Old 01-09-2014, 05:49 PM   #7
Sammy
WES or GMC Paul. I would stick with a board vendor that deals daily with our trucks and not just a mail order company that never had a column apart before.
Might try some penetrating oil, sewing machine oil, or even brake cleaner. Most of the column's I have had apart had lithium type grease hard caked on the switch causing them to be stubborn. A squirt of WD 40 after a few minutes freed the switch. After 40+ years you would be stubborn n brittle too.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
