Old 01-28-2014, 12:59 AM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Wanted: Dims for Aux Battery Windshield Washer Bracket (Right-Side)
I'm looking for dimensions "A" and "B" for a passenger side windshield washer bottle bracket, please.
A=distance bracket moves out from fender
B=lower hole to bottom of washer bracket
(Pictures borrowed from DeadheadNM)
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-28-2014, 01:18 AM   #2
71Dually
71Dually's Avatar
Re: Wanted: Dims for Aux Battery Windshield Washer Bracket (Right-Side)
Just measured the one on my CustomCamper/30.
This is what I came up with:
A - 1-1/8"
B - 9/16"
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72
1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code"
1970 Mercury Cougar "Eliminator" 351C-4V C6
1972 Ford Ranchero GT 351C-2V C6
1974 Honda XL-350
Member of the "6 C's and a D" 1-Ton Fun Club!
71Dually is offline   Reply With Quote
Old 01-28-2014, 09:07 AM   #3
badpeanut
badpeanut's Avatar
Thank you!
A - 1-1/8"
B - 9/16"
Is 1-1/8" to the top hole (not the bottom)?
'70 GMC LWB trailer
Old 01-28-2014, 01:34 PM   #4
71Dually
71Dually's Avatar
No, 1-1/8" was for dimension "A"
9/16" is actually from the top hole and I see "B" should be from the bottom hole so I've been caught not following directions so that was one big screw up.
It was a bit difficult to accurately measure in the truck (in the dark with a flashlight didn't help either). I figured removing two medium sized screws this morning might help overcome my one big screw up last night. So I pulled out the bracket and I'm revising dimension A and this time correctly measuring dimension B from the bottom hole per the instructions on the diagram.
So the good stuff has been triple checked and is:
Dimension A - 1-1/32"
Dimension B - 2-3/16"
Hope this helps.
1974 Honda XL-350
Old 01-28-2014, 02:27 PM   #5
badpeanut
badpeanut's Avatar
This is exactly what I need; thank you!
I'm going to make the Z-shaped bracket for my truck (probably going to use 1/8" steel plate) and I wanted to make sure it would fit.
'70 GMC LWB trailer
Old 02-22-2014, 07:16 PM   #6
badpeanut
badpeanut's Avatar
Here it is:
'70 GMC LWB trailer
Old 02-22-2014, 09:06 PM   #7
sKnNyPpY
sKnNyPpY's Avatar
Wow! Nice work.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 02-23-2014, 03:23 AM   #8
71Dually
71Dually's Avatar
Looks good, great job.
How does it fit for ya? Looks like it'll get 'er done.
1974 Honda XL-350
Old 02-23-2014, 11:03 PM   #9
badpeanut
badpeanut's Avatar
It fits fine! I wouldn't have gotten it to clear the hood without your dimensions. Thanks!
I was able to extend the 5.06" location dimension from the power block to about 5.5" to give more side terminal battery clearance and still clear the hood hinge.
'70 GMC LWB trailer
