"Junkyard Dog"
![]() Join Date: Jan 2008
Frame cab mounts, xmembers, box mounts, spring hangers, etc
Here is a bunch of frame mounts and cross members that I cut off the last two 2wd trucks. These parts have been hot tanked and if wanted I will acid dip any of them at no cost. Must specify if wanted. Paypal no fees or MO. Plus shipping. Thanks, Tom
Pic 1 form a 70 chev/gmc C10 with leaf springs front cross member 25.00 center cross member 40.00 cross member just forward of the rear end 40.00 cross member just behind rear end 25.00 spare tire support 12.50 very rear cross member 30.00 rear/rear spring mounts 25.00 each front spring hangers 25.00 each rear cab mounts 20.00 each front cab mounts 20.00 each core support mounts 10.00 each box mounts total of 6 - 2 fronts, 2 centers, 2 rears 10.00 each shock mount 15.00 sway bar mounts 8.00 each Pic 2 from a 72 chev/GMC C20 with leaf springs front cross member 25.00 center cross member 40.00 cross member just forward of rear end 40.00 spare tire support 12.50 rear cross member 30.00 rear/rear spring hangers 25.00 each front spring hangers 25.00 each rear cab mounts 20.00 each front cab mounts 20.00 each core support mounts 10.00 each box mounts total of 6 10.00 each shock mounts 15.00 sway bar mounts 8.00 each e-brake cable mounts. 5.00 each hyd brake line bracket 6.00 D60 bump stops 5.00 each
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
| Bookmarks |
