#26 |
![]() Join Date: Nov 2007
Re: New Info
I really like my scan gauge. I use it for the digital speedo, a very accurate fuel level gauge, temp gauge, and tach. Of course you can see any gauge you want like the average fuel economy in the picture. You can calibrate it very accurately over time. The 17.8 mpg is correct.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
#27 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#28 |
meowMEOWmeowMEOW
Re: New Info
Handheld tuners arent' the same thing....and most handheld tuners are really only useful on certain vehicles. When I had late model chryslers', you had to have one for the srt4/8s that we did, but since working with late model GM efi, there just isn't a replacement for HPT. Buy a scanguage, save the rest of the money.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#29 |
Re: New Info
I just bought the Scan gauge II, it is nice but unfortunately it is telling me I am only getting 14-15 mpg at 70mph
#30 |
meowMEOWmeowMEOW
Re: New Info
It uses injector pulse to guess that, assuming you calibrated the tank and fillup system, that still might be off. The mpg calc isn't really that great, tho I find its usually as accurate as the lie-o-meter that comes on cars these days.
That being said, I don't think thats terrible for hurling a brick into the wind.
#31 |
Truck and auto performance nut
Re: New Info
even with these bricks....rpm at cruise still makes a huge difference in mpg. If you want the big mpg numbers...your cruise rpm needs to be at or below 2k rpm...every 100 rpm's or so above that is dropping the mpg that much more. the lower the better (to a degree).
My TBSS with 4.10's is running like 2200-2300 rpm at 70mph and 2500 rpm at 80mph (IIRC)....and it rarely gets better then 17mpg. I had a bigger/heavier 6.0L full time AWD, 2001 Sierra C3 that got better mpg's with its 3.73's.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#32 |
meowMEOWmeowMEOW
Re: New Info
^ see mine's all wacky because I have a 3:73 and turn the same RPM's roughly (4l80e), and I can get 17-19 give or take freeway (but I also have those steel 12" wide wheels in back)
#33 |
Re: New Info
well I rechecked and I was off on the rpm's.....70mph is closer to 2500rpm with the 4.10's.
tire height makes a difference too. is there a difference in an 80e's OD ratio and a 60e's? seems they are close...like .05 or .10 difference or so. can't remember. ![]()
#34 | |
Old member
![]() Quote:
#35 |
Re: New Info
Just flip the switch on the back to "4 cyl" mode and all fixed on your tach...
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#36 | |
Old member
![]() Quote:
#37 |
Old member
Played with the scan gauge today. I got it to take the transmission codes and it saved it but it has no signal showing!
Can are will the computer tunner be able to turn this on in the computer when he does the tune? I was told the 4l80e should have the signal in the computer in a stock setup which I realize mine isn't. Anyone have any thoughts on this? I sure would like to have a temp reading on the trans. ![]() ![]()
#38 | |
Re: New Info
#39 |
Old member
Mine only comes on after cranking it up. It works fine just no signal from computer n the transmission.
