Old 02-06-2014, 09:02 PM   #1
KrazyRay
KrazyRay's Avatar
Debate is over. Pex is better than copper
At least for using on striker plates! I bought a new striker at autozone and installed it on the driver side of my 87 GMC and then I sleeved pex pipe on the passenger side. Both doors now shut easily, but the passenger side was pretty much free. It was suggested on another thread so I thought I would try.
KrazyRay is offline   Reply With Quote
Old 02-06-2014, 09:35 PM   #2
bnoon
Re: Debate is over. Pex is better than copper
I did that a few weeks ago. So much better I can't even believe it!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 02-06-2014, 10:28 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Big truck Nylon air line works too. And comes red n blue
Old 02-07-2014, 01:38 AM   #4
willett
Another Day, Another Dollar
willett's Avatar
Cool! Never thought of that!!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-07-2014, 01:58 AM   #5
cory d
cory d's Avatar
I just used a piece of pvc I found in a junk pile.
is it this stuff? i am guessing the 3/4" is OD. if so. $6 for 10 feet is cheap. and you could giv some to your buddies and keep spares in the truck http://www.homedepot.com/p/SharkBite...2?N=5yc1vZbuty
cory d is offline   Reply With Quote
Old 02-07-2014, 02:06 AM   #6
cory d
cory d's Avatar
searched around. looks like people are using half inch.
http://c10forum.com/forum/showthread.php?t=15889
Old 02-07-2014, 01:04 PM   #7
Wrecked1982
Wrecked1982's Avatar
does it wear out fast?
Wrecked1982 is offline   Reply With Quote
Old 02-07-2014, 02:13 PM   #8
bnoon
Correct. 1/2 inch. The 3/4 works but is too big and can catch/pinch weird. I tried that first and then went back and got the 1/2 and it works better without pinching. Also, Menards had it cheaper than Home Depot. I got a 3' section for under 3 bucks, plus I slid it into their bag sale for an extra 14% off.
Granted I've only had it on a few weeks, but there is no wear at all that I can see. The bushing rolls as it slides into the lock mechanism, so I'm guessing wear will be minimal. People have been doing this for years. Plus, I've still got 2'9" left after doing two trucks... I'm guessing I will run out of years before I run out of PEX tubing.
Old 02-07-2014, 02:41 PM   #9
dieseldawg142
dieseldawg142's Avatar
nope, my boat trailer had little plastic sleeves in the spring bushings that disintegrated, made some out of grey pex-they lasted for yrs!
dieseldawg142 is offline   Reply With Quote
Old 02-07-2014, 07:46 PM   #10
manimal
manimal's Avatar
does the washer come off? i tried on my Ford(pretty much the same style stiker) and the washer was staked on....
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 02-07-2014, 08:48 PM   #11
KrazyRay
KrazyRay's Avatar
Try putting the washer in a vise while you spin the striker and it should unthread.
Old 02-07-2014, 08:51 PM   #12
bnoon
The last washers on mine were easy enough to spin off by hand.
Old 02-07-2014, 09:34 PM   #13
Wrecked1982
the trailer spring shakle bolt sleeve is a nice idea also ,ill try it for sure
Old 02-07-2014, 10:47 PM   #14
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I sleeved my original strikers about 2-3 years and still going strong. And if they did wear out, the minimum length of pex pipe is like 8 feet.. so the 5 bucks for the stick of pex will last the life of the truck and its siblings...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-08-2014, 12:01 AM   #15
bnoon
3 feet sections available at Menards and 3 bucks. Still, no way I'll ever use it all.
Old 02-08-2014, 03:05 AM   #16
Maynard
Oh, hallelujah. I'm on this at sunup. Thanks for posting this.
Maynard is offline   Reply With Quote
Old 02-08-2014, 10:03 AM   #17
1slo_camaro
subscribing so I can find this in a few weeks when i get back to my truck
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 02-08-2014, 07:31 PM   #18
rusty76
rusty76's Avatar
Grey pex is Quest. You won't find that in stores any more. It's been discontinued for years. Stuff was a problem child, but pex is cheap and everywhere now. I get scraps off jobs for different things. Now I need to use it for my strikers.....
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-09-2014, 11:59 AM   #19
Axle
Axle's Avatar
It lasts a lot longer than the electrical tape I used to wrap around the strikers.
Alex.
Axle is offline   Reply With Quote
