Old 02-20-2014, 11:49 AM   #1
manimal
manimal's Avatar
Firewall differences?
Ok, so another question about my "77"...I had to strip down the interior because of mouse poop....so I am now in the reassemble process and want to install a new firewall pad....I'm "thinking" the cab haas been changed and the old vin plate attached to it. Reason is the front headlights and core support are 1980(square headlights), the wiring harness matches the 78-80(plastic fuses and different wiper motor) the bed has fuel doors and the fuel system(tanks and switching valve) have a return line( PO made one from engine to switching valve from copper tubing)....
So what I want to know is...what is the difference in the firewalls?(different shaped holes or locations?) The pads are listed 73-79 and then 80-up?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 02-20-2014, 11:50 AM   #2
manimal
manimal's Avatar
Re: Firewall differences?
and BTW it has a "77" frame...verified the vin on frame rails....
-Lance
Old 02-20-2014, 05:08 PM   #3
walkerb
walkerb's Avatar
If your talking dash pad, you need the early one if the vin plates on the door pillar.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 02-20-2014, 05:22 PM   #4
rs74
rs74's Avatar
I think he is referring to the pad that is on the floor that goes up under the dash.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-20-2014, 06:16 PM   #5
walkerb
walkerb's Avatar
Oh, gotcha
Old 02-20-2014, 06:59 PM   #6
manimal
manimal's Avatar
Yep....the insulation pad that goes on the firewall inside under the dash.
-Lance
Old 02-20-2014, 07:25 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the differences that I can remember was the ac and non ac cabs have different holes if you have a 3 on the three there is a separate hole ( I think they weren't on the tree after like 80 maybe im wrong) Its been so long I don't recall since I put the 81 cab on the 76 frame
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-21-2014, 08:06 AM   #8
chebyshortbox65
chebyshortbox65's Avatar
I don't think there are any except the 81-87 cowl hood hinge area I have a 81 and stripped 73 cab and there basically identical just diffrent holes punched both are a/c cabs all the areas that can be drilled are there even the hole for the ecm harness on 83-87 just my .02
chebyshortbox65 is offline   Reply With Quote
Old 02-21-2014, 10:23 AM   #9
roger97338
roger97338's Avatar
I read it as "....moose poop..." at first.
roger97338 is offline   Reply With Quote
Old 02-22-2014, 04:52 PM   #10
manimal
manimal's Avatar
-Lance
