Re: brake light staying on...
How did you "cut out a section and replace"? What did you use to replace it? Was it a wear hole or a corrosion issue? I would replace that entire section of line at minimum. If it's not an obvious mechanical damage issue I would replace all the lines. It's actually not a huge job and you will know what's good when you finish.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
| Bookmarks |
