Old 02-23-2014, 06:09 PM   #5
jasonroman
jasonroman's Avatar
Re: brake light staying on...
Originally Posted by imjeff View Post
How did you "cut out a section and replace"? What did you use to replace it? Was it a wear hole or a corrosion issue? I would replace that entire section of line at minimum. If it's not an obvious mechanical damage issue I would replace all the lines. It's actually not a huge job and you will know what's good when you finish.
Jeff
my guess is a wear hole. not sure why me slamming on brake to keep out of garage would blow it out??
i used a pipe cutter. plumbing tool, to cut the section of pipe out.
then used compression fitting. picked up a straight section of brake line.. 6 inches or so. and cut to needed length
6 bucks in parts.
leaks gone. but pedal is still smush and lights still on.
jasonroman is offline   Reply With Quote
