Old 03-01-2014, 08:59 PM   #1
dman1982
dman1982's Avatar
5.3 swap advice/questions
i bought a 2004 5.3 and 4le60 trans yesterday, has the whole harness, no ecu, or pedal or mass air, I've already ordered the pedal, been looking into getting a ecu, and mass air sensor and air box. I'm looking for advice....looking for companies to send my harness and ecu (once i get it) to get chopped up and tuned, and any other advice as to stuff i might need, and was wondering if i can use my transfer case...i have a np208 or if i could buy a adapter and use a stock one from a 2004 chevy? this is my first swap and trying to make it as painless as possible
this is going into a 84 k10
here is what i got done today... http://67-72chevytrucks.com/vboard/s...d.php?t=618692
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-02-2014, 02:40 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 5.3 swap advice/questions
With the DBW stuff, be careful that your components match. If you picked up the engine seperately from the pedal (and I hope the TAC, I didn't see it listed), then you'll want to make sure that you try to get TB+ECU+PEDAL+TAC from the same year and vehicle if you can.
I would also suggest going to a brick n mortar dyno tuner over the mail order tunes if you can. There is a definite horsepower and driveability gain, and it beat having to get the thing tuned twice....a large number of mail order tune customers end up getting a dyno tune after-the-fact.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-02-2014, 07:53 AM   #3
truckdude239
truckdude239's Avatar
I used WWW.lsx-harness.com
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-02-2014, 08:52 AM   #4
dman1982
dman1982's Avatar
thanks for the advice, i did forget to mention that i didn't have a tak, kinda sucks i ordered the pedal already...so should i order the tak and ecu together? will the system not work if they are not from the same vehicle? i plan on getting my harness and ecu taken care of so i don't have a million extra plug ins and etc that i don't need....kinda a newbie here in the LS area..doing this for power and fuel economy
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-02-2014, 08:52 AM   #5
dman1982
dman1982's Avatar
Originally Posted by truckdude239 View Post
how was they?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-02-2014, 05:02 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If the TB, TAC, Pedal and ECU arent' from the same year/vehicle, then you need to make sure they are as close as possible. Different years used different calibrations for the pedal sensors, and certain models didn't use the TAC (even though the plug on the harness might still fit, it won't be setup correctly.)
Using components too different will result in a "DBW Mismatch" error, which can show itself a handful of different ways. Anything from lack of pedal response, to no control of the pedal whatsoever.
Old 03-02-2014, 05:07 PM   #7
dman1982
dman1982's Avatar
thanks man...i appreciate it a lot....im trying to get everything from the 04 truck model, thats where the pedal came from....now i got to get a ecu and tak...ill pay a little extra for correct parts
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-03-2014, 04:52 PM   #8
dman1982
dman1982's Avatar
well i wasn't able to find a ecu and tac from the same vehicle, i did find them from the same year tho...hope it all works out
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-03-2014, 08:30 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Was it another 04 truck/van that had a v8? If so, your fine.
Old 03-03-2014, 09:26 PM   #10
truckdude239
Originally Posted by dman1982 View Post
how was they?
i ahve no issuses with them it was good and fast and it started right up second turn of the key
David fuller
2000 Tahoe 5.3l 378
Old 03-06-2014, 08:19 AM   #11
dman1982
dman1982's Avatar
i sent mine to a guy that lives pretty close to me and the turn around will be a week or so, a lot of the companies i talked to said it would take close to a month...i don't have the patients for that lol...
how did you do your linkage and fuel set up?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
