Old 03-03-2014, 01:04 AM   #1
Frijolito1988
u joint conversion question
Hey guys here is my question
I have a 72 c10 with a TH400 transmission. I also have a 5 lug rear end . The u joints are not the same when i try to connect the driveshaft to the rear end. The rear end is much smaller.
Do they sell a u joint with 2 small ends for the rear end , and 2 bigger ends for the th400 driveshaft ?
Frijolito1988 is offline   Reply With Quote
Old 03-03-2014, 03:27 AM   #2
Molberg
Molberg's Avatar
Re: u joint conversion question
Yes they do... I did the exact thing to my 72 gmc I had. I went to a one piece driveshaft at the time as well.... From the donor truck I took the tranny from.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 03-03-2014, 07:39 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's a common question so I took a picture of the last one I installed to show the part number you need.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-03-2014, 01:56 PM   #4
Frijolito1988
Awsome!
Looks like my local parts store has it, going to go check it out during my lunch break
Old 03-05-2014, 12:25 AM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
Yikes, I wouldn't put a precision joint in my neighbors lawnmower.
What size joints are you using? 1350, 1330, 1310, 3r? Spicer and neapco both make decent ujoints built within some tolerances.
The precision 372 is for 3r-1310 so if the "big" caps have inside keepers (notice the flat areas on the inside of the trans yoke posted) and the "small" cap side is also significantly more narrow it might be the ujoint that you need.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
