Old 03-09-2014, 12:23 AM   #2
Ziegelsteinfaust
Re: should i mount ford f-150 long travel suspension?
I have a 66 F100 that is in project status, and from the experience of I-beams to CV front end. I would say if you really want Long travel I beams get a Ford. Yes you can make them work, but the frame widths are extremely different.
I had a C20 cross member for a couple of weeks when I first got started on my F100 with the idea of making it fit. The Fords wide frame will practically slide over the Chevy frame, and you will effectively have a Z in the frame when connected. If my memory is correct you would have to shave the frame rails of the Ford about a 1/2 total to get it over the GM rails.
If you do this you will not want to run the early forged I beams due to them being rear steer, and you would have to mod you column to adapt along with wiring.
I would run the later beams post 87, and gain front steer which gives you the ease of hook up.
Or you could try to find a clip from a E150. They are front steer, but rather or not the have support for long travel suspension I do not know.
Either way I would use the 3/4 ton version, and get the camper special brakes. This way you have the factory big brake option.
Ziegelsteinfaust is offline   Reply With Quote
