Old 03-11-2014, 04:05 PM   #201
59stepside
59stepside's Avatar
Re: 1959 Chevy Truck
Engine pic
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 03-11-2014, 04:08 PM   #202
59stepside
59stepside's Avatar
Engine 2
USCG Aviator
C-130
Old 03-11-2014, 06:55 PM   #203
FarmerSid
FarmerSid's Avatar
I got the exact same seat but mine is around my kitchen table! LOL!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 03-11-2014, 08:11 PM   #204
59stepside
59stepside's Avatar
That is AWSOME !
I'm at a tuff spot, I thought it would be fairly easy fabricating the front part of the radiator and bumper mount.... I think I'm just tired of fabricating right now because I feel so overwhelmed by getting it welded up and square and not having the front end crooked. And I think I might have moved the wheel a bit to far forward. But no changing that now.
USCG Aviator
C-130
Old 03-11-2014, 08:45 PM   #205
Kim57
Kim57's Avatar
You're doing a real nice job on it.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-11-2014, 09:08 PM   #206
FarmerSid
FarmerSid's Avatar
59Stepside, are you anywhere near the Harland Check printer plant? I've been to Tampa quite a few times at that plant. I guess now it's called Harland Clarke. The Tampa guy's used to call me "Oh Canada". Treated me to the "Cabaret". Follow me? LOL! I think your 59 will end up being the same as my 51. After many and I mean many beer, there's going to be enough shimming room to adjust your front end. I was out pondering and sipping and figure it's only beer and welding wire. Both can be restocked.
C4 IFS & D44 IRS
5.3 HO L33
Old 03-11-2014, 09:37 PM   #207
bigtim44
bigtim44's Avatar
Thumbs up Re: 1959 Chevy Truck
Great work, your front wheel looks centered to me, on my truck I bolted the front clip on just using the top and bottom bolts on the rear of the fenders, mounted the inner fenders and bolted them to the rad support, I then lifted the whole front clip off and on as one piece while I was test fitting it and getting the rad support mounts in the right place and trimming the inner fenders.
Here's a shot of my 59 at about the same angle to show you the wheel placement.
Originally Posted by 59stepside View Post
That is AWSOME !
bigtim44 is offline   Reply With Quote
Old 03-12-2014, 12:12 PM   #208
59stepside
59stepside's Avatar
I'm not sure where that plant is, I will have to search a little bit to see where it's at. And well put , just welding wire and beer I guess and time...
USCG Aviator
C-130
Old 03-12-2014, 12:15 PM   #209
59stepside
59stepside's Avatar
Sounds good, I think your truck looks great. I will def do what you did by lifting it on and off as a whole
USCG Aviator
C-130
Old 04-18-2014, 09:12 AM   #210
59stepside
59stepside's Avatar
Front
USCG Aviator
C-130
Old 04-18-2014, 09:13 AM   #211
59stepside
59stepside's Avatar
Front 2
USCG Aviator
C-130
Old 04-18-2014, 09:15 AM   #212
59stepside
59stepside's Avatar
My kidos, I couldn't help but snap a picture when the were playing on/around the bed in back yard!
USCG Aviator
C-130
Old 04-18-2014, 09:16 AM   #213
59stepside
59stepside's Avatar
Side
USCG Aviator
C-130
Old 04-18-2014, 09:17 AM   #214
59stepside
59stepside's Avatar
Front rad.
USCG Aviator
C-130
Old 04-18-2014, 09:21 AM   #215
59stepside
59stepside's Avatar
Hard to see but it's on flat tires w/ 14" rims and touching the ground. I'm going with 17" rims up front to keep the the truck out of the scrub line. I'm going to order rims and tires today. I'm going with vision legend 5 -142 chrome 17's and 20's.
USCG Aviator
C-130
Old 04-18-2014, 09:24 AM   #216
59stepside
59stepside's Avatar
Rims
USCG Aviator
C-130
Old 04-18-2014, 08:13 PM   #217
Kim57
Kim57's Avatar
Looking real nice.
That pic of the kids looks cool (old time vibe to it).
Nice rims.
Kim
My build thread
Old 04-19-2014, 09:28 AM   #218
bigtim44
bigtim44's Avatar
I like the stance,get them radiator support mounts finished and you'll be cruising. If the bottom hose outlet on the radiator hits the anti roll bar ,just slide the radiator up a wee bit and drill some new mounting holes in the rad support.
Old 04-19-2014, 09:40 AM   #219
59stepside
59stepside's Avatar
Thx Kim and bigtim,
Crazy thing is, I went just a little more forward with the wheelbase so the rad support mount was right on the steering box. I cut everything around it so it would clear the steering box. So ended up loosing the original mounting spots on bottom of support. I did some fabricating and got it on there. I decided to move the radiator in front of the support and that created a lot of extra cutting and fitting to get it right. I think it looks pretty sweet with it so close to the grill, but now I need to figure out a different way to latch the hood.
--anyone ever have an issue with the rear of the hood sitting up real high when closed. But can push it down with hand. It was like that before. But it's even worse now.
USCG Aviator
C-130
Old 05-02-2014, 09:25 PM   #220
59stepside
59stepside's Avatar
Rims and tires are on. Ordered the cool ride airbag kit because with the 2" drop spindles this thing is pretty much on the ground. I have an inch or so from bottom of headers and tranny pan.
And I will drop the rear when time and money permits, but goal is to get it drivable right now...
USCG Aviator
C-130
Old 05-02-2014, 09:27 PM   #221
Kim57
Kim57's Avatar
That's going to be real low.
Kim
My build thread
Old 05-02-2014, 10:16 PM   #222
59stepside
59stepside's Avatar
Yeah, to low to drive it... I'm hope that I can get it high enough with the airbags to have a decent height to get around town w speed bumps and driveways.
USCG Aviator
C-130
Old 05-03-2014, 11:55 AM   #223
_Ogre
_Ogre's Avatar
stock spindles will get your static ride height correct and level out the truck
they will also safe you the cost of bagging it
do you plan on c-notching the rear? you will spend lots of time clunking the frame if not.
with stock springs plan on a minimum 4'' notch, 5'' would be better
i used a 3'' notch and had to use air shocks to keep off my bump stops
shop air compressor timer
Old 05-13-2014, 03:33 PM   #224
59stepside
59stepside's Avatar
Thanks ogre. The drop spindles are brand new and paid $$ for them because I had to get new spindles and didn't want to invest in airbags right away. So I figured I would pay a little extra and get the 2" drop and bag it later. So I just went ahead and got the front airbags to solve my ride height issue and get the bags I wanted in the long run.
USCG Aviator
C-130
Old 05-13-2014, 03:34 PM   #225
59stepside
59stepside's Avatar
Front susp
USCG Aviator
C-130
