Old 03-11-2014, 01:17 PM   #1
cliffs78
got a three on the tree, and cant find parts.
Hey fella's, I've just got my hands on an old fleetside that is near to my heart. I had one alot like it when I was 16, learned to drive in it and have been on the lookout for one for... oh about 20 years.
So the long of the short is. Have any of ya'll located and or been able to rebuild one of these three speed column shifters? With new or aftermarket parts..
I know its not a very desirable set up, and all my buddies are tellin me to just install a floor shifter, or an auto, or go 4/5 speed and be done with it, but I wanna stay original. Thats why I bought this particular truck, nostalgia..
Thanks in advance
I'm needy...
need stuff for a 78 halfly, 250, 3 on the tree.
cliffs78 is offline   Reply With Quote
Old 03-11-2014, 01:43 PM   #2
walkerb
walkerb's Avatar
Re: got a three on the tree, and cant find parts.
Good for you sticking to originality! Search the forum for threads. I've seen posts about bushing, etc....
Mine was a 3 on tree until the owner before me moved it to the floor. Keep us updated
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 03-11-2014, 01:58 PM   #3
cliffs78
thanks for the tip, the bushings in the linkage arms appear to be good, and intact with the metal sleeves.
The problem with it is that the "arm" for 2nd/3rd gear will kinda fall or stay in or near the 3rd gear position.
Pardon me for not knowing the correct terms. but on the column, the part that actually moves the linkage rods, wont engage the 1st or reverse linkage rod all the time..
I found a post somewhere on an adjustment for these and am attempting to adjust it, hoping for the best, but I see one plastic bearing cup cracked, and the bearing itself looks to be a bit worn..
bearing cup
this is the "actuator" for the lack of better terms..
and this piece here, I'm hopin' is supposed to be 3/4 cut..
I'm needy...
Old 03-12-2014, 02:58 AM   #4
1774btcrew
1774btcrew's Avatar
bearing cup
All of the parts you are showing seem visually okay. The plastic piece you mention is cracked and this is very common on all columns. All of the pieces you mentioned won't have anything to do with how it shifts. basically you have the plastic bearing holder, bearing, bearing retainer(3/4 cut piece) and a clip to hold it on. As far as the actual 3 on the tree specific stuff I have no idea. I do have factory manual and would be happy to scan the pages for you if needed though.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 03-12-2014, 03:00 AM   #5
1774btcrew
1774btcrew's Avatar
Or since you are local in phoenix I could print out the pages from the manual and give them to you.
Old 03-12-2014, 03:22 AM   #6
cliffs78
Hey that would be great!! As I'm unable to find any PDF stuff so far. And seem to have misplaced or left behind my old manuals...
Where bouts are you located?
I'm needy...
Old 03-12-2014, 03:23 AM   #7
cliffs78
So, I'm guessing it's mostly an adjustment issue?
I'm needy...
Old 03-12-2014, 02:02 PM   #8
cliffs78
So I'm a little embarrassed to say, but in my defense I'm a class 8 mekanik..
Here it is, I think I got the linkage actuator squared away, but still having difficulty changing gears. Or more appropriately selecting the intended gear.
slop in the shifter arm pin.
I'm going to pull the column back out, and tear it down completely and then try and find another column in a j/y hopefully... if not maybe a little creativity with some jb.
I'm needy...
Old 03-12-2014, 11:40 PM   #9
1774btcrew
1774btcrew's Avatar
Good luck on your hunt! There aren't very many of them out there but they do show up. I was at 3 wrecking yards today and didn't see any of them.
Old 03-13-2014, 12:04 AM   #10
TwoFiftyShifter
I miss driving 3OTT. You should watch the chase scene from the 1978 film Driver. YouTube it if you haven't seen it.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 03-13-2014, 06:12 AM   #11
D13
D13's Avatar
The column wears internally, the gates get all beat up and then the column wil hang 1-2 or get locked in 3rd.
The later 3/4 ton trck have a heavier trans and seem to have a more solid column. At least my 81 never had a linkage issue wheras the 77 does.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-13-2014, 10:20 AM   #12
walkerb
walkerb's Avatar
Super hard columns to find. Find someone to rebuild yours before you yank it. Have it back in a week. Good as new.
Old 03-13-2014, 10:59 PM   #13
cliffs78
I was under the impression that the three on the tree was only used in half ton's. What are all the applications for these? It would be great to know there are more for availability!
I'm needy...
Old 03-13-2014, 11:03 PM   #14
1774btcrew
1774btcrew's Avatar
These do show up occasionally. I saw one a few months ago at the wrecking yard. I will keep my eyes open for one
Old 03-13-2014, 11:03 PM   #15
cliffs78
I can rebuild it myself if I could find parts, or a diagram... I have it out and will ship it to ANYWHERE if they can promise me they will make it like "new" again. But I doubt thats a possible, since I cant seem to find anything on these online.
Have you got a place near you that works on these old shifters? If so could you give my their info, so I could contact them? I'd love to have this thing like new again SOON!
thanx!
I'm needy...
Old 03-13-2014, 11:06 PM   #16
cliffs78
Appreciate that btcrew! , btw, would you have a line on any thing internal to the column, or perhaps pieces to the column in new or aftermarket?
I have cash! lol
I'm needy...
Old 03-14-2014, 08:52 PM   #17
walkerb
walkerb's Avatar
I found a stolen and recovery shop that did air bags and steering columns. A good auto body place can recommend one.
I just wanted it work correctly and im glad I spent the coin.
Old 03-14-2014, 11:23 PM   #18
DPowers
One foot in front of the other
DPowers's Avatar
Might try these guys:
http://www.columnsgalore.com/index.htm
DPowers is offline   Reply With Quote
Old 03-15-2014, 02:51 PM   #19
cliffs78
Thanks for the tips, but that sounds about as complicated as just finding the parts...
I'm needy...
Old 03-15-2014, 02:56 PM   #20
cliffs78
Originally Posted by DPowers View Post
AWESOME!!! Sure appreciate the link DPowers!!! I called them this morning but unfortunately they are closed on the weekends, but I left a msg and hope to hear back from them on monday. The did have a listing online for complete rebuilt column for $575, but the ol' lady kinda threw a fit... Their page showed that they will have parts available online soon, so hoping I can sort something out with them, possibly a whole kit, or find a way to itemize just the parts I need.
Thanks again man, that is what I have been looking for!! Outstanding!!
I'm needy...
Old 03-15-2014, 03:04 PM   #21
cliffs78
pretty sure do to abuse this piece is trash.. and hopefully I can get a replacement thru Dpowers link.
Not sure what to think here, it appears bent, but not sure if this is supposed to be bent, or if this happened from abuse...
this pic also shows a broken shim, and the little white pieces are some sort of tube guide/shims that have worn down over the years.
MY thinking is, adding up all the play, and slop from these worn and broken components are adding up to ALOT of play near the bottom of the column where it counts.
So if I am able to acquire all the little pieces needed, the ol truck should be back on the road here shortly!!
Thanks again for the help guys!
I'm needy...
Old 03-15-2014, 10:30 PM   #22
cliffs78
Thought I'd share some pics of the ol' truck, I know how much everybody likes pics!
title matches the odometer, and reads 99k, been sittin for atleast 4 years.
I'm needy...
Old 03-16-2014, 11:24 AM   #23
hatzie
Moderator
hatzie's Avatar
Three on the tree setup.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
Snag the service manuals for 73 & 74 from my service manual thread.
The 78 Wiring and Unit Repair manuals are up. I'll be posting the 78 service manual soon but the 73 & 74 manuals have a lot more theory of operation info than the later year manuals.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-16-2014, 02:42 PM   #24
cliffs78
YOU ARE THE MAN!!!!!!
Thank you for the help, awesome work!
Being able to read factory service manuals is sooooo helpful, I have now got some reinforcement to some of the ideas I have about returning the ol girl to a like new feel. (as far as the shifting goes.)
1. replace detent springs, balls or lever which ever applies (still have to identify trans I have) in the cover plate.
2. now have an exploded diagram and names to match the parts for ordering, like wave washer.
3. adjustment for bottom bearing, I had it figured out, but knowing the factory setting of .005'' is key!
So glad you posted that! Thanks again!!!
I'm needy...
Old 03-17-2014, 06:15 AM   #25
D13
D13's Avatar
Some heavy 1/2's, some BB cars in the 60's, 3/4 ton trucks with 250's and possibly 292/305's. Mine's a 1981 light 3/4 with 250 inline and the HD 3 speed and no other options. I'm not sure exactly what is different but it has the big clutch and a different option code. And the column shifting seems much more robust than any of my earlier stuff.
1987 2 ton
