Old 03-22-2014, 10:29 PM   #11
gdavis
gdavis's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
Originally Posted by Vic1947 View Post
Hey George.
The tapped holes the hinge bolts thread into should be in a flat plate, they're not welded nuts. The plate is held captive inside the door pillar with a spot welded cage around it to provide additional adjustment. Depending on which holes are stripped, you might be able to access them with the door open. I'd first attempt to tap them the next size up from the outside. Use a taper length (long) drill bit to open the stripped hole and an 8 point socket to thread the tap in with an extension and a ratchet. That has the thinnest profile and would give you the least chance of boogering up your paint. If the fender/door edges are too much in the way, going thru the kick panel is probably your next best option. If you do one hole at a time, you won't lose your adjustment. Good luck! Vic
Thanks Vic. I think I will try the step up bolt first. Then if that fails I will go thru the kick panel. Thanks for the information. I will do one bolt at a time. good advice.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
