Old 01-28-2014, 09:00 AM   #76
Leroy-B1
Re: Vinegar for rust removal
Cool stuff
Leroy-B1 is offline   Reply With Quote
Old 01-28-2014, 02:54 PM   #77
benwah
benwah's Avatar
I have also cleaned scale out of radiators with the stuff!
benwah is offline   Reply With Quote
Old 01-31-2014, 03:12 PM   #78
grs
Originally Posted by 1963c-10 View Post
are the bezels aluminum or steel? mothers has a great aluminum polish also. i have used the never dull also w/good results
I used never dull on the aluminum side pieces on my 66. They looked great. Then I wiped them with a wet rag, and they went instantly dull again.
grs is offline   Reply With Quote
Old 02-01-2014, 02:25 AM   #79
Captainfab
60-66 Nut
Did you strip the clear anodizing off of them first?
Old 02-01-2014, 12:13 PM   #80
grs
No. And some of the parts were new.
Old 02-02-2014, 12:37 AM   #81
Captainfab
60-66 Nut
You need to remove the clear anodizing from aluminum before you can polish it. Oven cleaner works good for that.
Old 02-02-2014, 10:45 AM   #82
grs
Old 03-28-2014, 09:14 AM   #83
1963c-10
1963c-10's Avatar
Put this on the build thread...but thought it might be more use here to show the results. Been working on getting the fleetside assembled now that I have a clean title back and have been soaking some more parts. I have gone to a 75% vinegar and 25% clr solution and its sped up the process by about 30%. Still getting the same great results......a pic of the tailgate chains which were left in a 5gal bucket of water by the PO for an undisclosed time frame....they looked rough before 3 days of soaking.
1964 Short bed trailer
Old 03-28-2014, 12:04 PM   #84
Improbcat
Improbcat's Avatar
I may have to give this a try for all the hardware & little brackets I'm pulling off as I repair the front rust. Does it hurt any to leave stuff soaking too long? I don't want to leave the bolts in a bucket for a few weeks and come back to find them dissolved.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 03-28-2014, 01:34 PM   #85
1963c-10
1963c-10's Avatar
Ive left steel bolts in for up to two weeks with no issues. I do rinse with a baking soda & water mix....just a 1/4 box or so in a 5gal bucket. I've had great success with the vinegar. The 25% CLR mix is something new I've been doing and it seems to help cut the soak time down some. After a few days soaking, I take a wire brush to them, resoak for a few hours or another day, do my baking soda and water rinse and air dry. It will give the metal a nice prepped surface for self etching primer (which I use on all bare metal). Posts some pics of before and after too if you don't mind.
Old 04-05-2014, 05:54 PM   #86
crazyhenryj
I put my headlight buckets and after a week it was clean bare metal. I sprayed with rustolyum and it came out awesome. The 292 6cyl water jackets are crusty rusty so I put a few gallons of vinegar and letting it set for 3 months now so we will see what happens
crazyhenryj is offline   Reply With Quote
