Old 04-11-2014, 10:37 AM   #1
Thilo
Thilo's Avatar
New guy- question about electric fans.
Hey folks.
I have a '72 K10. Just installed the AC. Will be adding condenser electric fans (being shipped).
The truck has a dual electric fan setup, but it was about 90 degrees the other day and the temp crept up a bit without AC connected yet. I'm worrying about L.A. 110 degree days sitting still on a "freeway" (parking lot!) with the AC blasting.
Is there an electric dual fan that you guys KNOW will fit and work well on this truck?
350 with some kind of cam that makes it lope on idle.
It just seems like this is not a new concept and someone somewhere knows for sure the "BEST" one to use.
If anyone has more than anecdotal suggestions (like CFM comparisons, one having been used in extreme conditions like mine by multiple users, etc) I would be most grateful!
(I'm not opposed to wrecking yard options).
Or do I just go back to the belt driven fan and be done?
May peace accompany you always.
Thilo is offline   Reply With Quote
Old 04-11-2014, 07:47 PM   #2
litew8
litew8's Avatar
Re: New guy- question about electric fans.
Going back to a stock fan/shroud would be the easiest route.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 04-11-2014, 08:01 PM   #3
Z10
Z10's Avatar
Originally Posted by Thilo View Post
Hey folks.
Do you have a fan shroud for the fans? If not you probably need them. Are you pushing or pulling with the fans? You need to be pulling.
You can check out my build thread for a look at what I did.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 04-11-2014, 09:13 PM   #4
Thilo
Thilo's Avatar
Well, with the aluminum radiator and pulley set up it's not just "bolt the stock parts back on". This is how I got it.
I found a Flex-A-Lite 298 that seems to be right?
<ine are pullers but 12" and they don't cover entirely. That may be "a" problem. But they seem weak. Small motors. I can't even find them on the net to get the CFM rating.
The 298s seem much larger and will cover the entire surface almost perfectly.
Thoughts?
Old 04-11-2014, 09:17 PM   #5
Thilo
Thilo's Avatar
Z10: Wow! Beautiful install!
I'm looking for more "basic" though. This is my work truck and I need to work.
Old 04-11-2014, 09:27 PM   #6
imjeff
imjeff's Avatar
Locate a stock shroud and a fan that fits in the opening well (both fore and aft as well as diameter. I have air on my 72 big block and don't overheat. It has a stockish fan, shroud and a double pusher set on the condenser, but they have never come on...in 12 years of daily driving. It has the old stock small block radiator as well.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-11-2014, 09:38 PM   #7
Thilo
Thilo's Avatar
The 298 seems a good fit.
You're running all electric with no problems?
Do you know the CFMs of the radiator fans you're using?
Ever run the air sitting in gear not moving for an hour in 110 degrees?
(I'm in L.A.)
Old 04-11-2014, 09:49 PM   #8
imjeff
imjeff's Avatar
(I'm in L.A.)
Sorry for the misunderstanding. I am running a stock fan with a "just in case" set of pushers that have never come on.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 04-11-2014, 10:12 PM   #9
Z10
Z10's Avatar
Thanks Thilo.
I just so happen to have a stock shroud in good shape if you decide to go back to the factory set up.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
electric fan
