Old 04-19-2014, 04:40 PM   #1
truckdude239
truckdude239's Avatar
Re: What flywheel to use?
Id wether have the 4l80e over the 400 the 4l80 is as bullet proof as the 400 but has over drive no sure on flexpkate
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-19-2014, 04:58 PM   #2
akdg87
akdg87's Avatar
Guessing your LQ9 came out of a Denali or Escalade Platform and was hooked to a 4l60/65. So next question is the flexplate on your LQ9 flat or dished?
Also chances are if it came with a 4l80 attached then its more than likely an LQ4 and in that case you the th400 will bolt right up
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 04-21-2014, 02:12 AM   #3
ekgguy
ekgguy's Avatar
I will have to check on the flex plate. It is wrapped up at my dads shop right now. It did come out of an Escalade and I assumed that it was a 4l80, it was sold to me as one and I resold it as one. I ran the numbers from the motor and it is definitely a LQ9.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline   Reply With Quote
Old 04-19-2014, 05:02 PM   #4
pwradder
pwradder's Avatar
i recently had the same question about a 700r4, what i was told is that the flexplate will work-but the holes in it need to be elongated by about half a hole. also you need to use a spacer between the flexplate and crank that gm makes and is available through summit racing with bolts.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 04-21-2014, 02:13 AM   #5
ekgguy
ekgguy's Avatar
I saw a post that talked about the spacer and bolts so I have the part numbers for both if I need them. Thanks,
Matt
