Old 01-03-2004, 12:51 AM   #1
72bigblock
hauling a cab
hi i am hauling a cab today. what should i set it on? chris
72bigblock is offline   Reply With Quote
Old 01-03-2004, 12:56 AM   #2
Gee_Emm
old tires work good for that kinda thing, or make a block set up out of some wood
Gee_Emm is offline   Reply With Quote
Old 01-03-2004, 12:57 AM   #3
krazy_texan
krazy_texan's Avatar
i would just set it on your trailer and strap it down really good and you should be good to go.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-03-2004, 01:02 AM   #4
Sweet72
Sweet72's Avatar
I hauled mine on a trailer on it's back using only scrap lumber to protect it from damage, cab needed paint anyway. Tie it down with cargo straps as krazy-texan says.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-03-2004, 01:03 AM   #5
Clancy68
yep i put mine in a trailer with some wood blocks under the cab supports. if it still has all the stuff in the front like heater box or a/c...what ever, it will tend to be really nose heavy, so keep an eye on that if thats the case.
--Scott
Clancy68 is offline   Reply With Quote
Old 01-03-2004, 01:20 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Is it a finished cab? If you haven't done anything to it yet, just toss it in the bed of your truck. Won't even need any straps either.
Old 01-03-2004, 01:39 AM   #7
Chevelle454
Chevelle454's Avatar
"Toss" it in the back? I have been trying to figure out a good way to haul my cab, too.
I have to haul it 20 miles to get it painted, then another 20 back again to put it on the frame. It is extremely heavy in the front. Is there some way I can make something that I can use to roll it over gravel with? Something that is like $20 or less.
So far, the only ideas we have are to use a heavy-duty home built swingset to hoist the cab up, back the trailer under, and lower the cab. But then how do I get the cab off in the new location? Arg....
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 01-03-2004, 01:49 AM   #8
Longhorn Man
3 guys can move a cab no problem...even better with 4 guys.
if you are ready for paint, don't "toss it in the bed".
Old 01-03-2004, 08:47 AM   #9
72bigblock
off to get it now. thanks everybody. chris
