#176 |
Re: Finally starting my 5.3 swap!!
ouch
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#177 |
#178 |
lol funny
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
#179 |
#180 |
Well I was talkin trash and carma got me man...fuel line came off
#181 |
lol uh oh!! how did it come out? what kinda fuel lines did u use? I used all rubber lines on mine.
#182 |
A mixture of nylon covered with rubber (to protect from heat) and rubber with all quick disconnects...I put one on there as a temp for startup and forgot about it
#183 |
be careful dawg...don't wanna be rolling down the street in a ball of fire.
#184 |
That'll just give me a reason to go faster!!!!
#185 |
did u do any work on ur truck today besides that fuel line issue?
#186 |
Haha...didn't have to...mostly done man...looking for a good bed then off to body work, I may switch out the doors tomorrow
#187 |
kool...didn't work on mine today....probably sometime next week
#188 |
So I've been trying to figure out why my trucks running funny and I narrowed it down to the idle air control. I found some vids on youtube of vehicles that are doing the same thing mine is... this is an example right here....https://www.youtube.com/watch?v=QHp6AKsmcVE......
so im going to try cleaning that along with the throttle body and see what happens.
#189 |
meowMEOWmeowMEOW
It was running fine before right? I watched your video from the previous page, but the audio from in the cab isn't much to go by.
The perennial question; scan for codes? IAC is controlled by a stepper motor, not a vacuum source or mechanical linkage like older vehicles. If you have a problem with that, for the most part its in the tune, unless you have another handicap with it. Make sure the maf is plugged in and sitting correctly, make sure you don't have an obvious vacuum leak. A very dirty tb can cause issues with the air gap on the blade, or worse if the bleed hole is plugged. Anything else change? This doesn't seem like an issue from first start right, since you've put a couple miles on her.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#190 | |
#191 |
Update...well worked on the truck a little bit today and we found out that only half the engine is firing...running on 4 cylinders....my buddy says either the coils arent firing or the injectors are not spraying so he said he's going to work on it next week and i might have back by next weekend.
