![]() Join Date: Sep 2006
Fixed the turning to much to the left problem
I fixed my turning to much to the left problem when using 73 to 87 front suspension. The first picture is the left tie rod and the 2nd is the right. I didn't have much room to adjust the left so It could toe the tire in more to the right and I only had so much room to adj the right side out. So I took the outer left tie rod end out and trimmed 1/2 inch off which allowed me to get more adj to the right and I turned the right side out as much as I could and that cured my problem. Had to throw in the picture of the truck up on the rack just because.
I did all this with the pitman arm parallel with the frame.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
![]() Join Date: Jan 2011
Re: Fixed the turning to much to the left problem
Nice to see you got it worked out.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks... I think the worst part is how easy it was. Took me a while to figure out what to do.
| Bookmarks |
