Old 11-12-2013, 11:07 AM   #26
ironroad9c1
Master Hater
Re: LT1 Motor Swap
remember the Iron LT1 heads flow almost 20% more than the aluminum ones. They are what the vortec truck heads were patterned after.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 07-02-2014, 11:30 PM   #27
iceship
Re: LT1 Motor Swap
Any one install a check engine light...
iceship is offline   Reply With Quote
Old 07-03-2014, 02:48 AM   #28
1981Stepside
1981Stepside's Avatar
Re: LT1 Motor Swap
Yup. Replaced the "choke/glow plug" amber warning panel with a "service engine soon" insert from a cluster from a tbi truck. Than jumped 12v switched to the indicator lamp socket (which has no circuit board connection if it is a non-diesel truck) and connected the check engine wire from the pcm to the ground side of the lamp as the check engine light activates on a ground signal from the pcm
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
