Old 07-17-2014, 10:25 PM   #1
FMCustomz
Re: Crown Vic front end on a 67-72?
Crown Vic front on 1967 c10
FMCustomz is offline   Reply With Quote
Old 07-17-2014, 10:27 PM   #2
FMCustomz
The crown vic spring are too stiff. I just got new spring rate to sit the front down another 2 inches. I think this is a first for a C-10 so let me know what you think
Old 07-18-2014, 12:08 AM   #3
NONHOG
NONHOG's Avatar
I think I'd love to see some install pics.
Looks great!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 07-18-2014, 02:52 AM   #4
Andy4639
Old member
Andy4639's Avatar
Cool Re: Crown Vic front end on a 67-72?
Well as said before. Enough money and time anything is possible. Good job. Would like to see more pictures of the install and some details on it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-16-2014, 09:09 PM   #5
JakeDW
JakeDW's Avatar
But but but Thats not bolt on.LMAO
Jake
JakeDW is offline   Reply With Quote
Old 12-16-2014, 09:12 PM   #6
Ziegelsteinfaust
Jake
Yes it is right after you weld on the support brackets it just bolts in.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-16-2014, 09:19 PM   #7
JakeDW
JakeDW's Avatar
Ha ha true that.
Jake
Old 12-17-2014, 01:25 PM   #8
Mtrhd329
If you are just looking to run the 5x4.75 bolt pattern you could run a 91 Camaro 1LE rotor and use the trucks bearings and brake. it is supposed to give you the smaller bolt pattern with just changing your rotors.
this is of course for the 81-87 front ends. but would be an easier option to swap in a newer crossmember and just run different rotors.
http://67-72chevytrucks.com/vboard/s...d.php?t=319487
Mtrhd329 is offline   Reply With Quote
