Old 12-16-2014, 09:09 PM   #1
JakeDW
JakeDW's Avatar
Re: Crown Vic front end on a 67-72?
Originally Posted by FMCustomz View Post
Crown Vic front on 1967 c10
But but but Thats not bolt on.LMAO
Jake
JakeDW is offline   Reply With Quote
Old 12-16-2014, 09:12 PM   #2
Ziegelsteinfaust
Jake
Yes it is right after you weld on the support brackets it just bolts in.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-16-2014, 09:19 PM   #3
JakeDW
JakeDW's Avatar
Ha ha true that.
Jake
Old 12-17-2014, 01:25 PM   #4
Mtrhd329
If you are just looking to run the 5x4.75 bolt pattern you could run a 91 Camaro 1LE rotor and use the trucks bearings and brake. it is supposed to give you the smaller bolt pattern with just changing your rotors.
this is of course for the 81-87 front ends. but would be an easier option to swap in a newer crossmember and just run different rotors.
http://67-72chevytrucks.com/vboard/s...d.php?t=319487
Mtrhd329 is offline   Reply With Quote
