Old 02-08-2010, 11:05 PM   #1
Strut
Strut's Avatar
Sanderson Headers
Any one running any of these headers?
http://www.sandersonheaders.com/inde...cPath=21_23_35
Just looking for some feedback on them......
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 02-08-2010, 11:12 PM   #2
vegaschevy
Re: Sanderson Headers
I believe that is the popular header most everyone runs on here.
vegaschevy is offline   Reply With Quote
Old 02-09-2010, 08:20 AM   #3
Strut
Strut's Avatar
Which set is most popular... Any Pictures?
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-09-2010, 09:08 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
keep in mind how low you are full length heads wear funny if your to low..I have a post about the 88 to 95 3/4 header to keep it above the frame rail..so far no feed back??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-09-2010, 11:00 AM   #5
DT1
DT1's Avatar
It might just be me but most of them look like they aren't tuned. Is this something that should be considered? I'm thinking about putting a set on my 350. I've never had headers on any vehicle because I prefer stock but I think, in this case, I'm going to trim my engine up for just a bit more performance.
DT1 is offline   Reply With Quote
Old 02-09-2010, 11:04 AM   #6
ANTHONY67
I have a pair they work very well.
ANTHONY67 is offline   Reply With Quote
Old 02-09-2010, 11:13 AM   #7
Fitz
These are Sanderson BB-4 blockhuggers. On my 67 Stepside they tuck up between the frame rails so nothing is hanging down and they did not require much in terms of cutting to fit. On the passenger side I needed to put a small oval notch in the upper part of the frame rail but it was only 3/8 inches deep and 2 inches long. If this motor was anything other than a 572 that would not have been required but the heads are very far apart on this tall deck block. They also required relocating the oil filter which I did.
Fitz is offline   Reply With Quote
Old 02-09-2010, 11:21 AM   #8
pat 70/71
pat 70/71's Avatar
I'm running em on a zz4 (block huggers) and they work great. thick flanges. I run copper gaskets& no problems. Pat
pat 70/71 is offline   Reply With Quote
Old 02-09-2010, 11:23 AM   #9
HuggerCST
HuggerCST's Avatar
I've got Sandersons on my '70, and I really like them. The head flange is very thick, (3/8") so there is no need for a gasket at the head, (high heat silicone only)and the collector is 2.5", so I just welded the exhaust pipe directly to a bolt on collector flange, eliminating the need for a reducer/collector. I also like the fact that they don't hang down below the frame, but they do hug the trans pretty tight, and I don't think that I could remove the trans without removing the headers first. I'm not sure what the part number is, but I think mine were made for early 90's chevy trucks.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-09-2010, 01:19 PM   #10
70stroker
70stroker's Avatar
How is it gettin the oil filter off? It looks a little tight
70stroker is offline   Reply With Quote
Old 02-09-2010, 02:16 PM   #11
Fitz
I did say it was relocated.
Old 02-09-2010, 09:01 PM   #12
Spoof
Spoof's Avatar
Mr. Fitz, Professor Spoof must point out that the tag line about "intra-personal" problems and explosives suggests that one is intending to blow ones self up. To blow up other individuals, the usual source of one's misanthropy would be the result of "inter-personal" problems. Class dismissed.
Oh yeah, I have the block huggers. There collecting nothing but dust right now in the basement. The Zoomies are cool!
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 02-09-2010, 09:24 PM   #13
BP68
BP68's Avatar
Check out my build thread. I have a set of the mid lengths on mine, and they fit and look (ceramic coated) way better that the long tube headmans I had.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 02-09-2010, 09:50 PM   #14
byrd
Union Electrician
byrd's Avatar
I have these and yet to be installed, they look to fit almost like the ramshorns
http://www.sandersonheaders.com/prod...products_id=62
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 02-09-2010, 10:59 PM   #15
pat 70/71
pat 70/71's Avatar
what he said , Pat
Old 02-16-2010, 07:01 PM   #16
Fitz
Take a SECOND look at the avatar!
Old 02-16-2010, 07:02 PM   #17
Fitz
Originally Posted by pat 70/71 View Post
what he said , Pat
What I said!
Old 02-16-2010, 11:28 PM   #18
lilred67
lilred67's Avatar
i have a set, cc10 is the part # i believe. best headers i have ever had....
lilred67 is offline   Reply With Quote
Old 02-17-2010, 03:06 AM   #19
zammer
Addicted user
zammer's Avatar
I just got a set of CC 10 headers for my 71 2wd blazer from ECE and they don't with fit my 4 speed manual trans linkage Z bar. I have to do some mods to where the Z bar is pivoted from. Anyone else have this problem?
heres what they look like on the passenger side so far..
zammer is offline   Reply With Quote
Old 08-02-2014, 05:25 AM   #20
elf w/capital T
Dang those look nice!
elf w/capital T is offline   Reply With Quote
