Old 08-06-2014, 03:47 PM   #25
kevinr1970
Re: Dually Alcoa question
I didn't understand what you were saying at first but now I think I understand.
Yes, the Alcoa center caps are installed from the outside.
What I was proposing is to run the mounts for the simulator hub covers under the compression ring - between the compression ring and the outside of the wheel. Similar to what monte0185 has on his wheels.
Seems feasible, but if it is a risk of a mounting failure then I will forget the idea?
Originally Posted by SCOTI View Post
Check w/rs72z.... But.... I recall the 'hub' caps installed from the outside & will not fit from behind.
Looking through the thread I think you are talking about, it looks like he took the Alcoa lugs and had them zinc plated, then used the stock centers.
I have the centers, and the lug-nut caps/covers but think the simulator hub covers would be a cleaner look.
My gf is telling me to stop dinking (or another similar word...) around and just buy the lug nuts and get on with my life!
Originally Posted by monte0185 View Post
The lug nuts i have will hold the alcoa caps in place. However if you want the all Chrome look then your either gonna have to have the cheapy lug nuts plated or buy the expensive ones. Unfortunatley theres not really any alternatives. if you look up txfirefighter dually buld you can see what he did. pretty similiar to me but he has alcoa caps.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
