Old 08-20-2014, 06:59 PM   #1
69chevytrucker
69chevytrucker's Avatar
should i do it or will i regret it
should it take the body off this frame
and put this body on the blazer frame
69chevytrucker is offline   Reply With Quote
Old 08-20-2014, 07:00 PM   #2
69chevytrucker
Re: should i do it or will i regret it
or should i just do both and have 2 trucks lol
Old 08-20-2014, 07:05 PM   #3
69chevytrucker
the 69 is all new but 2wd i really want to make it 4wd the blazers body is not to bad the interior sucks pretty bad but i like the 69 more so if i put them in a pot and stirred it up and made a 4wd 69 of course i would have to get a diff box or cut it but has anyone ever done this and if so is there a build on it i could see
Old 08-20-2014, 07:17 PM   #4
davepl
davepl's Avatar
If I was going to the work of putting the body on a different series chassis, I'd pick a lot nicer chassis. You'd be doing a lot of work to pick up 3 years of technical advances. I appreciate that you probably doing it because it's a truck you have on hand, but the time investment is so much that sometimes it's worth looking for better parts before you put a couple hundred hours of your time in to 'save money'.
Why not a totalled 2000 Tahoe or something? Keep the ABS and stabilitrak and brakes and suspension and put your old body on it.
Again, I don't know if putting a '69 body on a 1973 is easier than putting it on a 2003. Go Stampeders!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-20-2014, 07:51 PM   #5
leftybass209
leftybass209's Avatar
N/m
leftybass209 is offline   Reply With Quote
Old 08-20-2014, 09:15 PM   #6
71swb4x4
71swb4x4's Avatar
The wheelbase on the Blazer is shorter, so you either have to extend that frame or shorten your shortbed.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-20-2014, 09:22 PM   #7
cdowns
cdowns's Avatar
it's a good way to get them both into the dumpsters
Old 08-20-2014, 10:29 PM   #8
franken
You'll regret ruining both.
Old 08-20-2014, 11:40 PM   #9
69chevytrucker
Thumbs up Re: should i do it or will i regret it
trucks a 69 blazer is 83 not 73 but i think i will leave the trucks as is the 69 is almost done anyway dont want to pull it apart again and i think i will buy some new sheet metal for the blazer and strip the carpet out and spray some bedliner on the floor drop a 350 in and jack it a couple inches then i will have a summer toy and a winter toy thanx for all the input guys
Old 08-21-2014, 12:14 AM   #10
BigRed76
BigRed76's Avatar
It may be an '83 but its still the same chassis that was used on a '73, so really it would only be upgrading the chassis 3 years...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-21-2014, 12:23 AM   #11
69chevytrucker
wasnt really looking to update was looking to make my 69 a 4x4 and right now i have a 85 front end on my 69 so i thought maybe a 83 blazer would maybe be easy to swap
