Old 08-25-2014, 11:47 AM   #1
RPBurris
RPBurris's Avatar
Can this fitting be removed??
I am running AN lines for my trans cooler to the radiator and I am trying to find out if the fittings that are on my radiator can be removed. By the looks of it I should be able unscrew the fitting with a 1 1/4" socket but I don't want to screw up the radiator. Has anyone else done this?
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 08-25-2014, 12:51 PM   #2
MARKDTN
Re: Can this fitting be removed??
NO!
That is the transmission cooler. You have to have the tank off to remove that.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is online now   Reply With Quote
Old 08-25-2014, 01:14 PM   #3
cdowns
cdowns's Avatar
you should b able to find an fittings that screw into that fitting to use your an type lines
Old 08-25-2014, 01:55 PM   #4
davepl
davepl's Avatar
While in theory you might be able to desolder them, don't. There are plenty of pipe to AN adapters out there. Probably as cheap as the fitting you'd need to install in the trans cooler if you even could.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-25-2014, 02:22 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
This^^^
There are fittings available that adapt the -AN lines to standard flare fittings.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-25-2014, 02:32 PM   #6
RPBurris
RPBurris's Avatar
Thanks for the help. I didn't think that fitting was meant to come off and glad I didn't try!
Old 08-25-2014, 03:31 PM   #7
csfields
csfields's Avatar
I took this route. I bought a aluminum transcooler and mouted it to the frame and ran AN lines to it from the TH400. Plugged the ones in the radiator.
I am almost done with the truck now, it was nice having these pics before the cab was on the frame to share.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
